Question about GE Washing Machines
Clamp under motor fals off, metal shavings under motor
Makes lound noise when in spinning cycle. I took off front cover to look at the motor, thier is a pin or clamp that had spen off, I had tightend it and put it back on, it came off, i did notice metal shavings under the moter.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Sounds like the clutch clip came off, the clutch is at the bottom of the motor, most likely you need a new clutch and/or .... if the washer is +5 years old
buy a new one.
Posted on May 21, 2009
Why does my washer (maytag mah5500bww front loader) make noise during the wash/rinse cycles but not during the spin.?
The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on the upper hose hitting the top cover ir a plastic injector mold standoff on the outer tub bearing housing, also a flat spot in the belt could cause a tapping noise. Something between the outer tub and wash basket. I have had to remove items lodged in the drain tube between the pump and tub, like bra under wires. Sometimes you can squeeze the tube and feel objects the ate lodged. I always take the tube off the tub side and run my finger all the way down to the pump impeller to make sure. I also check the I can spin the impeller and the nothing is in the pump. Hard to say with out being there. Where do you think the noise is coming from top , bottom , left , or right side?
Apr 30, 2014 | Maytag Neptune MAH5500B Front Load Washer
BELT BURNT FRAYED THEN BROKE, SOUNDED LIKE BEARING NOISE
It may be a garment stuck in between the inner drum and the outer shell
Aug 31, 2012 | GE WBVH6240F Front Load Washer
Drum doesn't spin
drive couple that model connects the motor to the transmission with a drive couple small rubber circle with two plastic pieces when this comes form the factory they make the small arms out of plastic the one you replace has metal around the inner shank which makes it last alot longer remover the cover then remove the two clips on the pump there unplug harness from motor take the two 1/4" screws out of the motor clamps use a flat screw driver to pry the clamps up do the top one first having your hand under the motor it willdrop downremove the motor and you will see the drive couple when reinstalling the motor align the couple with the spline of the small gear after you insert the motor drop the motor ona downward angle and hook the bottom clip then being the motor back up and hoolk the top clip reinstall the pump and the cover
Apr 30, 2010 | Kenmore 24032\24036 Top Load Washer
Making a loud noise when agitating almost sounds like a grinding noise but still washes okay
The noise would be indeed coming from the water pump.
To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump.
Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor.
Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. Check if anything jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary.
For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Feb 27, 2010 | Whirlpool Washing Machines
General electric top load washer model #wpre6100g1wt loud noise
Your problem could be one of 2 things either the base is pushed up in the center or the front apron is bent. The apron is the piece of metal that runs across under the top cover. To remove the front cover to see either use a putty knife to release the catch between the top and the front cover and pull front outward one side at a time.
Feb 25, 2010 | Washing Machines
My washer runs fine until the spin cycle then it started making a loud noise, and not spinning, i emptied it and let it sit, now it spins but not nearly fast as usual. and the noise is gone after letting...
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary. For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Sep 12, 2009 | Maytag Performa PAV2200
Noise in the spin cycle
Sep 12, 2009 | Washing Machines
When it spins it makes a lot of noise and moves around a lot
itmakes lound noise and there is powder dust on the floor under the machine and it washes ok but noise is when it spins and when the water goes out
Aug 13, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing machine making loud noise when agitating/spinning
Jun 29, 2009 | Westinghouse Washing Machines
Whirlpool Duet Sport Front Load - Spin Cycle Noise
Had one do this. Turn machine around look at bottom two corners. Machine comes with metal rods to stabilize drum during shipping. Installer forgot to pull those out on mine. Once I removed them noise quit.
Jul 07, 2008 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
156 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
