Question about Boating
1998 15 hp outboard propeller bush - Boating
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
To replace it take to a press to get old one out and to replace or take to a prop shop !
Posted on Jun 03, 2014
What year is my Evenrude 5.1 outboard
provide a model number and perhaps someone can assist you .
May 10, 2016 | OMC Johnson Evenrude 9 1/4" X 9" Stainless...
Replace a propeller bush on a 1998 15 hp outboard
if its a through prop exhaust then need to use a press to get it out and back in ! most marine workshops or outboard breakers will have a supply of sec hand props and pos exchange yours against a new one !
Jan 02, 2014 | Boating
I have an 85 HP Mercury Outboard and when you get to about 4000 rpm's it sounds like it is slipping, what can I look for..........
In the propeller is a rubber hub.It's between the driveshaft and the prop.Its job is to stop major damage if you hit something causing driveline damage.It will be starting to slip.Its called the rubber bush.It will need to be looked at.Take it to a prop shop because if you take it to a dealer,they will take it to a prop shop.More cost.Hope this helps
Jun 02, 2010 | Boating
I have a johnson 50 hp outboard when travelling in excess of 5 knots the prop stops turning and motor revs high.
In the hub of the propeller is a rubber bush that stops damage to the shafts and g/box if something is struck with the prop.These bushes do give way and are repairable.See your local boat shop or look for a specialist propeller shop.Probably the latter as the boat shops sends the props to them anyway.Its called the propeller hub bush or just the prop bush.Just take the prop into them and all will be good.Hope this helps you
Nov 19, 2009 | Boating
2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Oct 31, 2009 | Light Outboard Motor Boat Bass Fishing...
Help. recently cavitated my 140 hp 1989 mercury outboard motor at high speed.I Removed the lower unit several times but only goes in forward about 5mph. Please help Tx jack
Not really sure what is wrong.Do all the gears work?Does the motor rev properly.Did you change the height of the motor.If the motor etc. are all ok and the motor cavitated at high speed,you may have spun the bush in the propeller hub.The symtoms are,everything works ok but the boat can rev but will have very little forward propulsion.If this is it,the prop needs to come off and taken to be rebushed.The bush stops major damage to the g/box if the prop strikes something.Hope this helps
Sep 07, 2009 | RTO Outboard Motor Bass Fishing Boat Rod...
Boating Logo
43 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
