Haier tv sound
My sound isn't working, but I can see the picture. And it isn't with one channel, it's with all of them and I check to see if the audio is on SAP and it wasn't.
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
Check whether the sound is muted or not. Refer its user manual for this detail. If it is no muted, check the speaker/s first. If found OK, check and replace damaged component/s at its audio output section circuit. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Posted on Jan 03, 2014
SOURCE: aquos Channel Bar/audio bar
There is no factory option to stop the box from poping up every time the signal changes, which is what is happening. It has something to do with signal strength or the fact that your cable box is not set up for HD. Call your cable company to get a tech out to check your signal and set up your cable box because they do not come pre-set with HD defaults.
Posted on Jan 23, 2008
SOURCE: sylvania LD155SC8
i need remote control
Posted on Apr 12, 2009
FIXYA Benny
  • 165 Answers
SOURCE: how can I turn off SAP?
if you are using a digital TV is is possible that the frequency is slightly out or you have poor reception.
do a new channel serch first (automatic if you can
and see what happens
sap may reset also if you do this function.
Posted on May 05, 2009
roety
  • 585 Answers
SOURCE: I have sound but not picture on a Haier plasma tv
Hi my name is Roety,
I can help you with your issue ,
These Haier TVs go bad and I always install the repair kit part #?TV-3940-01
It includes the scan boards and an upgraded IC .
I can not find any kits in stock, but I know there some available online if you search or call a few places.
Mat electronics or sears parts direct may have some.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Apr 14, 2010
Testimonial: "this is very helpful,I will try it and let you know. NAVARRO"
BElectric
  • 1140 Answers
SOURCE: I have a Haier Tv
There is no dedicated audio board in the TV, the audio processing is one of the functions of the main board, also known as the AV board or motherboard.
I'm not sure whether your comment means you have a cable box or a direct cable feed and this is not the most technical answer, but I see this problem regularly with cable boxes and it's rarely a fault with the TV. Often the firmware/software in the cable box "crashes" and needs to be "re-booted". This is similar to what happens with a PC from time to time which is unsurprising as, essentially, these devices are computers.
I'd like to suggest that you reset your cable box before looking for replacement parts / numbers. Some cable boxes have a reset button on the front. Others simply need to be switched off and unplugged from the electrical outlet for a couple of minutes. If you're doing this, you may as well unplug the TV as well and "re-boot" it.
If this doesn't work, you should also try restoring the factory default settings on your TV:
1. Switch the TV on
2. Press the "MENU" button on the Haier remote to open the on-screen menu
3. Use the CH+/- buttons to highlight "FUNCTION"
4. Press the VOL+ button to open the FUNCTION MENU
5. Use the CH+/- buttons to highlight "Restore Default Value"
6. Press the VOL+ button to activate the restore feature
Please note: After restoring the TV to factory defaults, you will need to complete the initial setup again the same as you did when the TV was new.
If you have done all of the above and there is still no audio from the TV speakers, then there is a fault with the TV and you should post back to discuss options for repair.
Before posting back, please also try plugging headphones into the headphone socket on the back of the TV and check whether you have audio in the headphones. The headphone socket is next to the antenna connection socket.
Hope this helps.
Regards,
BElectric
Posted on Feb 09, 2011
My 42 in haier tv sound is not working, it was working friday before i went out of town come back and it's not making a sound, picture still looks good.
If your audio circuits have gone South then you have an issue with your main board of the set or the amps that power the speakers. See if you have audio voltage at audio output on set. If so issue is with amps and you can always connect your audio receiver to that output and get sound like that. I blew an amp and that is what I have been doing without any sweat.
Jul 23, 2017 | Haier Televison & Video
No picture but the red power button blinks each time it blinks there is a thumping noise from speakers and a clicking sound
try checking the fuse area, together with the capacitor & resistor may one of them is faulty. and also check for any bad soldered.
let me know
Oct 31, 2008 | Haier HTF27R11 27" TV
Haier Tv no sound
Check the setup menu to see if the audio isn't sent to the external audio jacks or the fiber port. Could be something as simple as having the volume muted too.
Jan 02, 2014 | Televison & Video
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
Haier tn201auv have picture but no sound
Check the interconnection cables for firmness. Check the audio inter connection cable for internal conductor break. Check with a new cable.
Jun 09, 2012 | Haier TN201AUV 20" TV
Audio isn't working
ya know I hate to say it but I've done this before. check the mute button on your remote. I've accidently hit mine before and it took me several days to realize it. lol. if it's not that. check the volume of the set itself, then check the volume with the remote....I know these are weird things to check, but they do & have happened, to me. lol. good luck & God bless.
Mar 21, 2012 | LG Televison & Video
I have a Haier 7"
U get some picture on some channel but very weak signal and fade out and get Error codes on the tv screen?Yes,than buy a stronger Digital antena design to get better and stronger longer recieving signal ranges.
Dec 15, 2010 | Haier (PDTB7) 7 in. Portable Television
No sound on analog channels Haier 22
took plasma tv from UK to europe, goodpicture but no audio on analogue chanels
May 04, 2009 | Televison & Video
Sound no picture
If you have the 3 RCA jack cables connected to the input jacks on the TV press input on the remote until the picture appears.
Apr 13, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
