Question about Samsung Office Equipment & Supplies
Unpause printer Printer: Monochrome, ML-1675 model is connected to a PC which I have accessed successfully with my MAC in the past through a landline ethernet connection, but which since installing CS5 Adobe software somehow changes the remote ML-1675 from "Idle" to paused "Paused" and will not print any document then sent to it. (It also appears to convert a .txt file to a .pdf file, which may have something to do with the problem). Meanwhile, another printer (an EPSON WF2540) connected in the same way, continues to work perfectly fine from my remote IMac. Also, my PowerBook laptop, similarly remotely connected to the ML-1675, can also print on it without problem. Could the problem be the installation of CS5?
cammykins
  • 149 Answers
SOURCE: Not a valid image file.
This sounds like something on the Hardware, on the way its uploading onto the computer. Does it do this with every image you try to scan onto PDF?
Posted on Oct 02, 2007
SOURCE: Brother IntelliFax-2820
Prints with a white line vertically down the page. How can I fix this?
Posted on May 14, 2008
SOURCE: we buy canon copier ir3035
(This is for your information)First ur problem is not mentioned clearly. You are mentioning network printing is having problem (this is ok) but it is not clear that printing from USB is having problem or not. And you did not mention the type and version of your operating system(OS) and the nature of your network. Installing driver is very crucially depend upon the OS and the type of network that you are having.
Let assume that you are having genuine MS Windows 2003 Server as the backbone of your network and genuine MS Windows XP SP2 as the OS of the client PCs. Some basic knowledge of networking is required to understand and execute the remedy mention below. And you should read completely first before trying out this.
For network printing problem of Canon ir3035, first check the physical network cable(UTP) if it is properly crimped & properly connected, then check the connectivity by pinging the IP of the copier (which is needed to set manually if there is no DHCP server in the network). If the copier is responding properly. Check again by pinging the server from the copier (which you will find under MENU and NETWORK OPTIONS of the copier). If both the way is responding properly uninstall the printer driver totally and restart the system. Re-install the USB driver first and then re-installed the network driver (before re-installing the network driver first check whether it has got the required IP from the DHCP server, if not assigned one according to your network). If there is no error message during the installation of the USB driver(normally USB installation does not show any error), USB printing should be ok. Thus USB case is close.
Then check the network by using the same procedure mention above. If everything is ok, you can carry out the installation process for network driver. This way there should be no network printing problem. If still there is the problem please check that you are not using pirated copy of OS. Network printing for ir3035 is not ok if pirated copy of OS is used. You have to get a genuine copy and will solved the problem A to Z.
Posted on Jul 29, 2008
tech435
  • 284 Answers
SOURCE: Continuous Fast Busy Signal
you might need to do a all job clear. leave me and email address and i will gladly help
Posted on Sep 22, 2008
SOURCE: I received an FLM551 laser fax/scanner printer that was sitting around
i need a driver also
Posted on Oct 07, 2008
How Do I fix Samsung Laser Printer?
I would suggest using plain denatured alcohol (you can buy at a paint store or a Home Depot type store.
Take out all of the paper and get access to the rollers. Use a q-time or reach in with a cloth (do not use a paper towel) with the alcohol to clean the rollers.
Sep 21, 2014 | Samsung ML-2010 Laser Printer Monochrome...
Samsung laser printer ML 2010 won't print
Dear
For mac pc you have to download the driver from samsung web site and follow the instruction there.
Aug 18, 2014 | Samsung ML-2010 Laser Printer Monochrome...
Samsung ML-1675 toner reset software
Dear you may check the link for the firmware.
Its also assumed that you have sound knowledge on update of firmware and its necessity.
You may try on your own risk and samsung void warranty on such type of work.
Thanks.
http://www.elektroda.pl/rtvforum/download.php?id=494027
Jan 27, 2012 | Samsung SCX-4300 Monochrome Laser...
How do i scan photos onto pc using an all in one samsung scx4300?
load software from printer cd and scan documents
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 22, 2009 | Samsung SCX-4300 Monochrome Laser...
How to reset samsung ml 2245
We have both software and Hardware solution for ml 2245 printer
Nov 17, 2009 | Samsung ML-1640 Monochrome Laser Printer
3 month old machine, low print usage, showed "Replace Toner". Replaced with Samsung cartridge but still showing Toner Empty message. Replaced with another new Samsung toner, but message will not go away....
you need to reset printer thorught software
We have Zero cost solution for samsung -scx-4300, ml-2240,ML
Nov 02, 2009 | Samsung SCX-4300 Monochrome Laser...
I need driver for samsungML1640 printer driver now to install printer on my pc
http://www.samsung.com/us/support/download/supportDown.do?group=&type=printersmultifunction&subtype=monochromelaserprinters&model_nm=ML-1640&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010400&disp_nm=ML-1640&model_cd=&menu=download
This is the link for the page where you can download the driver for your printer. If you cant click it you can copy and paste it in your browsers address bar. on the chart find your os. (windows xp,vista , or mac) then click on printer driver for that os.
Jul 04, 2009 | Samsung ML-1640 Monochrome Laser Printer
I am using samsung ml 2245 monocrom printer.. after printing 2*** print with the demo toner... it stop working and giv the error of toner exhuated..i refil the toner only single time.. plz tell me how to...
We have software to reset your printer
Jun 11, 2009 | Samsung ML-1640 Monochrome Laser Printer
Toner replace
reset your printer.
Jun 01, 2009 | Samsung ML-1640 Monochrome Laser Printer
Toner exhausted
go to this link
http://www.fixyourownprinter.com/forums/printer/59558
try this
http://img528.imageshack.us/img528/7835/reset.jpg,
I have tried, it works, but instead of shorting the chip permanently, connect a push button switch to the chip, this way you can still get both the page count for the refilled cartridge and get the reset facility easily accessible.
May 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
24 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
