Question about Dryers
Kenmore Elite Oasis Gas Dryer (110.77032600) no power
My Kenmore Elite Oasis Gas Dryer (110.77032600) just lost power mid cycle. Won't power up now (no lights, beeps, etc). Outlet has power. Don't see any similar situations online. Thoughts?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
Check the power cord
Posted on Jan 04, 2014
SOURCE: Kenmore Elite Oasis Dryer 67086 beeps!
I have been experiencing the same constant beeping throughout the drying cycle with the loud and soft lights alternating. After reading every post I could find related to this issue. I removed the top console and found the hidden tech sheet. I ran the diagnostic mode and got error code F 2 which means there is a failure or interface mismatch, whatever that means. Well, when I read that folks have spent hundreds of dollars to replace the part and the problem returns and since the dryer functions perfectly fine except for the beeping, I just removed the beeper from the control board (twisted it off). Crossed my fingers and put everything back together. Turned on the dryer and bingo, beep is gone and dryer works fine. I know this isn't a proper fix, but Sears doesn't have one either. I had a Sears Tech to my house right before the warranty expired and she had no idea what to do and said the dryer was so new, they didn't have any specs. She didn't even remove the top to get the tech sheet and check any of the connections or run the diagnostic test? Just kept pushing different buttons and unplugged and it seemed to reset, but of course came back. Hope that helps someone else who doesn't have the money to replace and knows that Sears won't do it. Good luck!
Posted on Nov 15, 2007
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
reg501
  • 413 Answers
SOURCE: Cycle Signal Beeping
The user interface button panel has failed and will need to be replaced.
Posted on May 29, 2008
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
Go to Sears and buy it! You cheap B.
Posted on Jun 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
How do I stop fluff cycles on kenmore elite dryer
There are two ways this can happen:
1. You set the timer to a cycle that activates this option
2. (If equipped) Turn the selector knob off on the control panel that you can activate this feature with. Every manufacturer calls it something different.
May 12, 2012 | Kenmore Elite Oasis 7808 Gas Dryer
The Dryer is working but stopped in mid cycle and gave me a code of PF
Power Failure. Press and hold start to restart dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 04, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Oasis 110.67087600 Dryer will not power up. No power at all. Prior to this it had a PF flashing. House power checked good.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
If no-go.. the timer is failed due to a power spike and must be replaced.
Apr 26, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite oasis dryer model #110.6708
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
I need the installation manual for a Kenmore Elite Oasis gas dryer. Specifically I need to know what water line attaches to the dryer (for steam), the hot or the cold?
Hello, Here's the link to view the owners manual and exploded view of the parts for your model. Once there, click on the exact model # you have (it's listed on your dryer's data plate) so you get the right one.
http://www.managemylife.com/mmh/owner_manuals/search?query=kenmore+oasis+elite+dryer+7808
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis dryer 110.6708 that gets too hot
did u clean machine filters? in the back of your machine there is a big silver pipe itmay need to be clean too
Jan 21, 2010 | Kenmore 67082 Electric Dryer
My kenmore dryer won't power on nor start a cycle.
my problem is solved without your help. thanks for nothing!!!
Nov 20, 2009 | Kenmore Dryers
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryers Logo
152 people viewed this question
Top Dryers Experts
