Falt cod P0470 and P2002 on my NISSAN EXTRAIL
I have a nissan primer with falt code po336 p
code p 0336 refers to crankshaft position sensor(CKP)--range / performance problem===causes insecure sensor / rotor --air gap incorrect ---wiring-- CKP sensor
Oct 22, 2015 | Nissan Cars & Trucks
HOW DO I FIX MY NISSAN NIVARA THE FAULT CODE P2002 PM OVER ACCUMULATED
This means the diesel soot elimination system is not working at its most effective range. The problem is related to using high Sulphur fuel, driving short distances, air leaks etc. It will clear itself if the vehicle is operated long enough to develop high exhaust temperatures.
Oct 02, 2014 | 2007 Nissan Navara 2.5
P2002 how to solve indicator ligth on dash board
Error Code:P2002
Description:
DTC P2002 Particulate Trap Efficiency Below Threshold (Bank1)
Possible solutions:
- Perform regeneration process. This process does not always solve the problem or the problem is solved for short term only.
- Remove/ Replace the Dust Particulate filter.
- Exhaust fuel addition INJECTOR ASSEMBLY. (Replace).
- Inspect turbo charger, in any.
- Mass Air Flow sensor.-
- Exhaust manifold convertor sub assembly
Mar 14, 2014 | 2007 Toyota Hi-Ace 220
Ryobi P2002 manual
Here it is
http://www.manualowl.com/p/Ryobi/P2002/Manual/111150
Apr 12, 2013 | Ryobi 18v P2002 String Trimmer P2102...
I have a 98 Nissan Pathfinder that will not pass emissions because of all these sensors that arent working. I was told they possibly have a bad wire. Like they all share a common and i have a short...
The first thing to do is to add an additional hard wire ground. Its easy, inexpensive and will help to ensure that a system ground falt is not causing random sensor falt signals to the computer resulting in check engine codes. Attach a new wire from the battery to the block to the intake manifold.I have had this problem and it took a long time to figure it out especially if you have multiple sensors falting. Would'nt think of a central ground falt but it does happen.
Dec 15, 2012 | 1998 Nissan Pathfinder
P2002 code is on
P2002 isn't listed code, are you sure about this?
Oct 04, 2012 | Cars & Trucks
Engine 1kd-ftv toyota it turble code oo1 p2002 particulate trap efficiency below threshold(bank1) what is replacement parts
Hello Dears'
I am a vehicles Mechanic, I have problem with this trouble cods P1226
the car don't give accelrator. If you kindly show me it please.
With best regard
May 02, 2011 | Toyota Passenger Cars & Trucks
Truck will not start
P1670 Electronic Feedback Signal Not Detected
P0344 Camshaft Position Sensor A Circuit Intermittent (Bank 1 or Single Sensor)
P0470 Exhaust Pressure Sensor Malfunction
Apr 10, 2009 | 1999 Ford F250 Regular Cab
10 people viewed this question
jasbo
jasbo
