Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Change ip address
Need to change ip address on router but cant connect to internet
  • fougzki May 11, 2010
    more info please
roadhawk
  • 25 Answers
SOURCE: IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Posted on Nov 25, 2007
Benimur
  • 6966 Answers
SOURCE: belkin wireless router
Your Belkin router is normally configured to get a dynamic IP Add from your Internet provider unless otherwise configured. Most ISP's network where clients/subscribers connect (through DSL) has a DHCP server that hands out this IP adds. If your router keeps on changing its WAN IP add, it may presumably be because:
1. Your router keeps on rebooting or powering on/off and everytime it turns on, it is given a new IP add;
2. Your ISP's DHCP server keeps on renewing its lease on the IP add given to your router.
Corrective measures would entail:
a. Do a full hard reset of your router and go through the installation setup again. Of course this would revert all settings/configuration to factory default; and/or
b. Contact your ISP and explain your concern.
In some cases, the router's MAC address has an issue that the ISP's DHCP is keeping a hard time recognizing it. this can be corrected with a firmware update.
Hope this be of help/idea. Pls post back how things tunrs up or should you need additional information.
Good luck and kin regards.
Posted on Feb 03, 2008
im4um2
  • 77 Answers
SOURCE: Belkin Router: F5D7230-4 V2000 not getting correct IP Address
Although I am generally knowledgeable in networking, your issue I think still lies with your Router settings. I will however offer you a site to visit that may help you to set up your router no matter what type of service your ISP is.
http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/f5d7231-4.pdf
It sounds as if the computer that is wired to the router should have an ip address assigned by router somewhere in the range of 192.168.2.2 through 192.168.2.149. The router that you speak of might have the ability to be used as a "bridge" thus throwing off some of the settings. It seems as though you have the ability to have the router set up its own WAN IP. Which is for the wireless aspect of the router. Even with that though the default gateway should still be the address that you type in the browser to access your router's settings. The Belkin web site did offer a firmware update for your particular model as well and I will include that site too.
http://www.belkin.com/support/article/?lid=en&pid=F5D7231-4&aid=5388&scid=221
Good Luck
Posted on Jul 02, 2008
SOURCE: belkin router f5d8230-4 ip address change
Call 661-588-4401 and he will take your money and Ipod and you will never see either again!
There address is 12316 Stonington Street Bakersfield, CA 93312 and they will tell you to send a money order for $89.00 and to make it out to Gloria Anderson or John Medeiros or Richard McNeill. BEWARE!!!!
Posted on Sep 17, 2008
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
THE PROBLEM IS THAT THE BELKIN RTR AND THE 660 HAVE THE SAME IP ADDRESS THE QUICKEST FIX IS TO RENAME THE LAN IP ADDRESS OF THE BELKIN RTR
Posted on Jun 12, 2009
How do i connect my WG302 to my laptop using a console cable?
if Windows
go to dosprompt on p.c or start run cmd <press the enter key>
type in ipconfig <press the enter key>
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ?
note the ip address of the laptop and the subnet mask
If the ip address is not 192.168.0.210 then go into the network settings and set the laptop up with 192.168.0.210 and then make it a static ip address.
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ? (if not restart the laptop ) and check again
Next question how did you connect the wg302 directly to the laptop was it directly connected or was it through a network switch or network hub. Most likely the Cable router or DSL router has a DCHP server assigning different ip address lease range. You can either change the ip address of the access point device to one in the original current router lease range and assign it as static for the wireless access point device in the dchp lease table or assign the wireless access point with the second ip address as an example 10.0.0.2 and make sure the router dchp server allocates above 10.0.0.20 then temporarily connect router to laptop and temporily set laptop with 192.168.0.210 and then log into access point and change ip address to 10.0.0.2 for wireless access point device and turn off its dchp server. Then change laptop to use dhcp while connected into network hub or network switch with original router and restart laptop wired back into original normal network.
Dec 04, 2014 | NetGear WG302 802.11g ProSafe Wireless...
How to convert local ip camera addresses to ip addresses to connect from internet
depend on what brand and type of the ip camera that you use.
in order to be able to access from internet:
- you need to use a router that connect to a switch and the camera
- the router must have UPnP Feature & Port forwarding.
- just in case your public ip address is dynamic, you will also need a ddns for redirection.
The basic concept is, you have to configure the network setting of the camera according to the router as a gateway.
usually, in the network setting, you will find a http port number.
change this number from default ( 80 ) to another number from 0 to 65535 ( example 50010 or 40000 , you can choose freely, it's recommended to use port above 50000 )
then find the portforwarding function in your router, then set the port number to the ip address of the ip camera.
if it's successfull, you can directly access the camera from the internet by entering your public ip address and the port number on your browser.
for example : http://itcomm-streets.viewnetcam.com:50001 << my ip camera demo unit.
Jul 02, 2012 | Android Apps
I have a Vizio VBR120 Blu-ray player and it won't connect to my internet using my NETGEAR WNR2000v3 Router. I have tried using an ethernet cable from router to the blu-ray player. I will not find an IP...
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Mar 05, 2011 | Vizio VBR210 Blu-Ray Player
I cant get into my ps3 internet i need help
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Oct 02, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I'm trying isolate parts of my network and I need to place a Dynex 4-port router right after my modem and then plug my office lynksys router into that. (At present, the linksys is plugged into the modem...
Modem <--> Dynex <--> your computer should work.
Connect:
Modem <--> Dynex <--> Linksys router <--> your computer.
Turn off all the above devices.
Turn the modem on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Dynex on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Linksys on, and wait for its lights to "settle" down to a repeatable pattern.
Turn your computer on, and wait for its lights to "settle" down to a repeatable pattern.
On your computer, click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
The Linksys router should have given you an IP-address for your computer, and the IP-address for the "gateway" (namely the Linksys router).
Start your web-browser.
Type http://192.168.0.1 (or http://192.168.1.1) to connect to the web-interface "inside" the router.
Access the 'WAN' settings-page on the router, to see what IP-address the Dynex router has given to the Linksys router, and what "gateway" IP-address that the Dynex router has offered to the Linksys router.
It might be best to change the range of "dynamic" IP-addresses that one of the routers hands out, e.g., '192.168.123.100' to '192.168.123.200' for the Dynex router, so that both routers don't try to hand-out IP-addresses in the *SAME* range.
Apr 05, 2010 | Dynex 4-Port Ethernet Broadband Router...
No internet connection...
Check your cable-connections:
AC power to the router.
Cable-modem <----> WAN-port on the router.
or
DSL-modem <----> WAN-port on the router.
LAN-port on the router <----> Ethernet port on your computer.
Windows 7 should show that you have obtained an IP-address,
starting with '192.168.' that was supplied by the router.
Note that some ISPs (Internet Service Providers) will require
that you tell them the MAC (Media Acccess Control) address
of the _ROUTER_ before the router will be able to connect,
through the ISP's services, to the Internet. Contact your ISP.
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
Cant connect to internet
Configuring router for Cable Internet (LINKSYS)
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Configuration Steps:
Step 1
Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' for password and username is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection Type to 'Automatic Configuration (DHCP)' option. Under Setup, click on MAC Address Clone tab. Enable it and click on "Clone My PC's MAC". Do this from the computer which the cable modem was directly connected the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router.
Step 4
Click on SAVE SETTINGS and then on REBOOT THE DEVICE including the cable modem to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.1. You can do this on your router under Setup > Basic Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Sep 02, 2009 | Linksys Wireless-G WRT54GS Router...
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
IP address
Hi tammyhope,
--RoadHawk
Nov 25, 2007 | Belkin (F5D7230-4) Router (587009)
Cant accses router
Pressing and holding the reset button on the router for about 5 seconds should reset the router, but you may need to connect with the router via an RJ45 network cable incase the wireless is not able to set it up The default ip address of the router should then be 192.168.2.1. do not use the windows repair wizard as this totally messes up your pcs ip address, make sure that your network wireless and wired adapters, are set to obtain an ip address automatically You shouldnt change the PPOE or PPOA settings, as they are the settings on which your ISP allows your router to connect to the server. Manually entering an ip address will effect the address of the router so keep the settings as enable DHCP to assign ip addresses automatically. Ensure when you have it running you save the settings so as you can reinstall them if neccasary.
Aug 20, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
195 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
