Question about Husqvarna 28cc Gas Line Trimmer
323L Husqvarna trimmer
I have a 323L trimmer. the primer bulb cracked and had a new bulb,plug and fuel line installed. picked it up from the shop yesterday and they said they couldnt fix. it fires the plug good has good compression but keeps filling the cylinder with fuel. cylinder looks good. not for sure if the lines on the primer are installed correctly doesnt seem to prime up correctly. i never had any trouble with it until the bulb cracked.
    President:
  • 1,902 Answers
This sounds like the carb needs to be adjusted like it is letting to much fuel into the cylinder. There is supposed to be fuel and air mixture in the cylinder to make it fire. If there is to much fuel what will happen is that it will just build up in there and the air wont get hot enough as it compresses to start the engine.
Posted on May 21, 2009
Need diagram of husqvarna 323l fuel line placement
I'll send you a link to the downloadable manual.
Sep 22, 2012 | Husqvarna 323L
I have a 124l e-tech trimmer and the prime bubble wont fill
Sounds like you have an air leak. Either in the primer bulb is split or punctured, hole or leaking fuel line or primer bulb base, and is sucking air instead of fuel.
Aug 20, 2012 | Husqvarna 124L 28cc Gas Line Grass Lawn...
Looses prime
Have you replaced the primer bulb 'base'.?
Jul 14, 2012 | Husqvarna 323L
Need fuel line diagram for Husqvarna 322L trimmer
There are only 2 ways the pipes can go on. there is a fuel tank out pipe and a breather/return pipe.
Jul 04, 2012 | Husqvarna Garden
My homelite sx135 line trimmer has a split primer bulb (clear rubber) - where can i buy a new one?
You can pick up the primer bulb at any local Loews, Home Depot, or your Ma and Pa mower shop. The bulb is pretty a generic one.
Sep 26, 2011 | Husqvarna 28cc Gas Line Trimmer
Both my Echo line trimmer and Stihl hand held blower. No fuel in the bulb on both, I suspect bad fuel. If so, how do I fix?
Check INSIDE the fuel tank. It is possible the fuel line inside the tank has deteriorated and the filter broke off. That would cause fuel line to FLOAT in the tank instead of lie on the bottom. This could easily be the cause of no fuel in primer/purge bulb. You probably need to:
Install new fuel filter..........Install new fuel Lines.......Install new primer bulb........Clean carburetor.
So in some respects, you are probably correct....no fuel filter equals bad fuel entering carb (but if none in bulb, doubtful much fuel (dried up maybe ) in carb.
Sep 06, 2011 | Husqvarna 28cc Gas Line Trimmer
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
The engine starts and then shuts down in 10 seconds.
fuel issue, check lines from tank to primer for cracks, check primer bulb, and carburetor. Tim
May 29, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna 323L Line Trimmer - Runs for about 5-10 seconds,
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwillneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to seedaylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Husqvarna Garden
Primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Husqvarna 28cc Gas Line Trimmer Logo
1,235 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
