Question about Worldwide 2001 Volkswagen Jetta Wolfsburg Edition 1.8L Alternator -
2002 jetta wont start it makes a clicking sound
My Jetta's engine wont start. Lights and windows work, but when I turn the key all I hear is a clicking sound.
  • 3,187 Answers
Starter motor fault or battery fault. battery can run windows etc when flat or damaged starting engine uses alot of amps. 40- 60 times more than a window motor.
Posted on Jan 10, 2014
My 2002 Jetta TDI wont Crank
Check fuses first. Crank/start fuse. IF that's good. Find the starter and hit it with a hammer or rod/pry bar as some one tries to start it. If it starts, replace the starter. It has a dead spot in it. If it doesn't, try jumping the small wire to the big wire. It will arc, but if it doesn't turn replace the starter. If it does turn, check the small wire for power when turning the key to start. No power, go to the crank fuse and check for power when trying to start, still no power. Then it is a break in the wire from there to the ignition switch. Or the ignition switch is bad.
Oct 08, 2016 | 2002 Volkswagen Jetta TDI
Why wont my 2002 jetta start ? get clicking sound no start
It is either your battery not charged enough to crank the engine or the connection at the battery is loose/dirty. I would check connections first.
May 25, 2014 | 2002 Volkswagen Jetta TDI
92 vw jetta,wont start,runs for3 seconds,when i turn ignition switch on,nodash lights,only battery light appears,no other lightslightup like before,locks work,dont understand what to do now
Is this a 92 Jetta like you describe or a 02 Jetta TDI? If it's a 92 Jetta, I can almost guarantee the ignition switch is bad. Common failure. They're cheap, but require special tools and experience to remove.
Oct 15, 2013 | 2002 Volkswagen Jetta TDI
97 jetta wont start when it's cold
need more info but could be the battery, starter, or ignition switch(if you turn the key and its not even cranking but you still have lights)
Jan 03, 2013 | 1997 Volkswagen Jetta
2002 jetta tdi,,now and then when i put the signal lights on they work fine & they will go off but i can hear the clicking noise you would normally hear when signals are on in the dash area aroung the...
I had a similar problem on my '99 Golf and it turned out to be a worn-out turn signal switch. When I replaced it, I found that the innards were corroded pretty bad.
Mar 01, 2011 | 2002 Volkswagen Jetta TDI
99 jetta wont start, lights and radio work, windows dont, it just wont turn over, its not the battery
FIRST IS THERE FUEL IN THE TANK, CHECK THE SECURITY AND CONDITION OF THE BATTERY TERMINALS / CHECK THE HT LEADS ARE SECURELY CONNECTED TO THE DISTRIBUTOR CAP / CHECK THAT THE HT LEAD TO THE IGNITION COIL IS SECURELY CONNECTED / CHECK THAT THE LT WIRING PLUG AT THE IGNITION COIL IS SECURELY CONNECTED / FIT NEW SPARK PLUGS / THEN SPRAY ALL ELECTRICAL CONNECTORS ABOVE WITH WD 40 .
Nov 30, 2009 | 1999 Volkswagen Jetta
2002 Jetta (gas) squeal at startup. Every time I
Sounds to me like you need to replace your serpentine belt.
Nov 01, 2009 | 2003 Volkswagen Jetta TDI
Turn ignition key but won't start..All power on, is it starter?
Can be a Junk Relay, access is limited, but giving the Starter a "crack" with a mallet, often cures the problem temporarily. But check the Battery terminals, and Cable to the Starter solenoid ,first for tightness and security.
Regards,DT
Aug 29, 2009 | 2001 Volkswagen Jetta TDI
Worldwide 2001 Volkswagen Jetta Wolfsburg Edition 1.8L Alternator - Logo
78 people viewed this question
Top Worldwide Electrical Supplies Experts
jhnolson
wadingriver
wadingriver
ka4iup
ka4iup
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
