I have a bush free view+ box. When I try to record a programme the message "timers are scheduled" appears and I am unable to record anything. What is this?
4 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Unable to do anything!!!
Did you finaleze the DVD after dubbing?
After dubbing material from hard disk to DVD you need to "finalize" the DVD disk to make it playable. You would think that this action would be accessible from the "Dubbing" menu. It's not. Each time, you have to go to the "Setup" menu, which is normally used for the initial setup of the video tuners and default values of record/playback preferences.
Are you deleting the files correctly ?
For example, If you choose the "Navigation" button on the remote to view a list of what you have recorded on HD and you see that several of them are no longer of interest and can be deleted, you have to back out step by step from the "Navigation" set of menus, then press the "Edit" button to first choose an action (delete) then get the same list of programs to choose the ones to delete
Have you used this machine in the past successfully?
Cheers
Posted on Feb 05, 2008
RFICKES
  • 51 Answers
SOURCE: unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Posted on Jan 03, 2009
SOURCE: I have purchased a Teac HDR2500T video recorder. I
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Posted on Sep 06, 2009
Every time I try and schedule a recording it tells me there are too many reservations. There are no reservations or data at all on the external drive. what should I do? Thank you Sue
The reservations that it means is the programme record slots available (the number of programmes that you can have set to record ) some boxes only allow 8-12 to be scheduled at a time
Apr 25, 2017 | The Computers & Internet
I have a LOGIK 1TB freeviw Recorder and the following message keeps appearing on screen 'Can't schedule recording. There is already a timer at the same time on this channel.' Ther is not a timer recording...
Check that there is no recording set! Go to Menu and then Library settings and delete anything showing! This should clear the message showing again!
Dec 31, 2014 | Televison & Video
How do I programme my digital thermostat?
Repost question with link to product manual, or photo of timer
This will allow expert to view the product and maybe help you program the timer to match your schedule
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 18, 2014 | Hardware & Accessories
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
How can i program a VCR plus with out a remote the timer light keeps flashing
Generally the timer flashing means that ethier a programme for recording is set to record or wrong information is added. You need to check the timer record menu to see if a recording is schedule. I suggest you might need to get a remote for the model or get a universal one. Placing a blank tape in a powering down, should see the timer stop, but if a recording schedule is there it will still be on. The only way to clear it (without the remote) might to let it record! You don't give the make or model so I can't say anymore.
Jan 17, 2011 | RCA Televison & Video
Samsung DVD-SH897M - Cannot get Time Programming to work
You need to contact Curry's direct, I am certain they will be able to send someone to explain it to you.
Jan 05, 2010 | Televison & Video
Panasonic DMR-ES40V VCR won't schedule record: Recently, the VCR will not do scheduled recording anything beyond today. I can schedule a recording and it appears OK (I get red light on panel), but I never...
I found this solution on one of your old notes (but a different machine). I set up a scheduled record for 11:59 PM to 12:01 AM for the current day, then set up the scheduled record for the next day. The VCR recorded both the initial 2 minute session and the later one which I wanted to record.
Dec 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Televison & Video Logo
Top Televison & Video Experts
