Hook up the power ,hdd led,power led, power switch on micro-star ms 7529
I need to hook up the power ,hdd led,power led, power switch on micro-star ms 7529
  • 979 Answers
Hello Randy, the terminals are located near the SATA ports. read your motherboard labels near it and you'll find the connectors, its very basic, you can figure it out. plus signs are green for the power led and orange for the HDD. read the wire connector of your PC casing.
Posted on Jan 03, 2014
map9966
  • 2351 Answers
SOURCE: i need to know how to hook up some mother board wires
Hi swiftty6, you can download the manual for this board from this link. http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=558
Than go to pg. 2-18 for a better picture showing these case connections.
Like this.
4b15236.jpg Enjoy!
Mike
Posted on Apr 04, 2008
kigwa2008
  • 68 Answers
SOURCE: PC Chips M955G Motherboard Front Panel Pinout
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Posted on Jul 25, 2008
myob247
  • 1342 Answers
SOURCE: wiring diagram of hdd.power reset .power
Here's a link to the support page for your board. You can download the User's Manual from there.
Click Here
Posted on Feb 23, 2009
mbase213
  • 728 Answers
SOURCE: where can i get fc micro star n1996 model ms-7211 audio driver
Hi mabellmk85,
You can find all the software and drivers for that board HERE.
Good Luck,
and don't forget to leave a rating,
Thanks
Mark
Posted on Sep 27, 2009
philw1964200
  • 124 Answers
SOURCE: I need a manual for a MSI, Micro-Star. Model,
You should be able to go to there web site and print out a Manual. If they do not present it then simply go to Google.com and type in "Manual for a MSI Micro-Star Model MS 7050 Ver 2.0. I have done for many of my electronics and for older computers as well. Should not be a challenge for you at all. Please let me know. I will gladly find it for you myself if have any problems!!
Posted on Jan 07, 2010
Zenith pc no booting display is going to sleep mode and pc are blinck green light
http://elektrotanya.com/msi_ms-7529_rev_1.1_sch.pdf/download.html
Apr 14, 2013 | MSI K8MM-V Motherboard
I need the manual for the MSI KT4V MS-6712ver::10a to plug in the power switch and the led's plugs and the hdd plugs
Hi, I found the manual for your MSI KT4V motherboard. You can download the manual from here: Click Here. The diagram for the power switch, LED and HDD plugs are located on Page 2-18.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | MSI KT4V (MS-6712) Motherboard
How to hook up the face plate of a emachine w3400 Wich includes 3 wires 1 power butten and 2 led lights
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
is the Front Panel header.
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
(Junction Front Panel 1)
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
Nov 27, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Jan 11, 2009 | MSI K8MM-V Motherboard
I need to know how to hook up some mother board wires
Like this.
4b15236.jpg Enjoy!
Mike
Apr 03, 2008 | Computers & Internet
MSI Slot 1 MS-6111 Motherboard
Click the link below which will take you a site that has a black & white shot & description of the board, Slot 1 MS-6111. It shows everything you need. Scroll down & listed is what goes where.
http://stason.org/TULARC/pc/motherboards/M/MICRO-STAR-INTERNATIONAL-CO-LTD-Pentium-II-MS-6111.html
please vote...
Feb 13, 2008 | MSI Slot 1 MS-6111 Motherboard
Pin connections
Go to the webpage below and scroll down a bit. There will be a picture and list of what connections go where. Good luck.: http://stason.org/TULARC/pc/motherboards/M/MICRO-STAR-INTERNATIONAL-CO-LTD-Pentium-II-MS-6117.html
Jun 14, 2007 | MSI Slot 1 MS-6117 Motherboard
Computers & Internet Logo
504 people viewed this question
David Payne
David Payne
