Question about Frigidaire Dehumidifier LAD704TDL
Ice build up on filter - Frigidaire Dehumidifier LAD704TDL
When set in smart mode it runs continuously and the core ices up this results in the filter not being able to be removed. water then runs all over the floor. This also happens in normal mode Very li
Ice builds up for two basic reasons:
  1. Impeded air flow. This causes the dehumidifier to run constantly as the humistat never reaches it setpoint as there is limited or no airflow over the coils. Even with a filter, the cooling coils can become clogged and render airflow restricted or non-existent. Check and correct as necessary.
  2. A low refrigerant charge. Systems can leak over time and become low on charge. This causes extended period of running and the resultant freeze-up. If the coils and filter are clean, have the system checked for proper charge of refrigerant.
Jan 02, 2015 | Dehumidifiers
Idylis 0526051 dehumidifier - ice build-up. After 7 months of use this started to make a laboured noise that was audible the floor above. I switched the unit off and noticed what appeared to be a "check...
Dust and dirt that causes loss of airflow through the coils is the most likely cause. The only other reason would be a low refrigerant charge to the compressor.
Dec 26, 2014 | Dehumidifiers
Wht does my dehumidifier keeps getting ice build up
Possibly dirty. Remove and clean all the filter parts and inner coil.
Be careful not to damage any of the cooling surface area.
Most of the time, you will get improper airflow from blockage.
Completely clean and try after to see if this corrects this issue.
Oh, a new filter if you have one.
Aug 05, 2014 | Dehumidifiers
A build-up of ice on my air conditioner behind the filter which is room size
Check air filter and check the access water drainage pipe for any conjuction
Nov 09, 2012 | Haier Hwf05xcj Window 5000 Btu Air...
Coils freezing up, is this normal during operation?
Check fan speed. Also if coil (it's the evaporator) is clean.
Jun 02, 2010 | Maytag M7DH45B2A Dehumidifier
Unit iceing uo
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 04, 2010 | Kenmore 54501 Dehumidifier
Coil freezes
go to a home building store or may be hardwhere and buy the spray evaporator cleaner and use as directer see how that works you may want to to put high pres air forst then break out the hose and cleener let me know if this helps
Apr 06, 2010 | Kenmore Dehumidifiers
Ice build-up on Danby Dehumidifier DDR583R
Make sure you have enough air moving over the coils. There is an air filter on some models which may be obstructed. Insufficient air flow will cause your problem.
Sep 17, 2009 | Danby DDR583R Dehumidifier
Ice build up
I would say you need a humid control on your unit.it may be running more then normal.
May 08, 2009 | Goldstar DH504EL Dehumidifier
Frigidaire Dehumidifier LAD704TDL Logo
Top Frigidaire Dehumidifiers Experts
Lawrence Oravetz
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
