Question about Kenmore Elite 45986 Front Load Washer
WSXH208A1WW washer water will not start
My GE WSXH208A1WW washer will not supply water. The door lock light comes on when it is closed but no water. Not sure what the issue is...?
SOURCE: Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
Posted on Jun 04, 2009
  • 4090 Answers
SOURCE: Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Posted on Aug 01, 2009
mnwarfield10
  • 452 Answers
SOURCE: front loader washer model 41744102301.
change door lock or check there is no signes of damage to door lock catch.if this dont solve it new pcb needed££££££££
Posted on Dec 30, 2009
Testimonial: "I did just that, I changed door lock and it worked. You hit it right on the bottom! thank you. Nick"
SOURCE: Door lock failure on Kenmore Elite He3
Remember to unplug the machine and to exercise caution when working with water and electricity.
There is a diagnostic mode that is possible to run, it can't run though if you have a door lock error since it will sense that first and not complete the diagnostics.
To start the diagnostic mode:
From machine off.
Press the Drain/Spin button once.
Press the Spin Speed button until No Speed is selected.
Press any of the buttons under Options four times, the same button will need to be pressed each of the times. I use the Prewash button.
Unlocking and locking the door manually:
Front panel below door 3 screws on bottom of panel.
Reach up on right side of drum.
If you pull the tab, ths is manual unlock.
If you close the door, it remains unlocked.
This tab is black, you can't see this unless it is removed.
The black tab pulls on a white slider to unlock, pushing the tab to lock does nothing, you will reach up along the black tab and feel a corner of the white tab, this pushes up easily when the door is closed or if the latch is engaged.
If you engaged the latch and it is closed but not on the door, you will need to pull the black tab down. Then use something sturdy to loop around the white hook inside the latch. I used a black clip that is commonly used for clipping paper or sacks closed, the ones with the chrome loops, just angle it around and pull firmly, remember to have the black tab pulled, but not hard.
To describe the door lock mechanism:
Access to it:
Bottom:
From bottom for manual unlock and lock.
See above on access details.
Top:
From top for removal and installation.
The top panel comes off by three screws from the back.
It then slides back a few inches and then is able to be lift.
Removal and installation:
Three screws from door side holds it in place.
There are three plug-ins to this mechanism, the two white/clear plugs have one press tab each to unhook it and the longer black clip has two on the same side (facing the rear of the machine).
You will move the mechanism into the washer so the close button and the latch area are clear of the face of washer.
There is a cream plastic harness support on the inside that is held by two posts from the mechanism.
The mechanism slides up then out from the harness support.
You need to be careful not to damage the drum seal.
It is out.
Installation is the reverse of removal.
Describing how it works:
You will notice that the mechanism is quite long.
The top part where the wire connector with two wires connected is solitary from the rest, it is just a button to sense whether the door is open or closed.
If the mechanism was opened you will see that the black button has a little tab that pushes a little red button on a rectangular unit when the door is open to keep the connection and is away from it when the door is closed to break the connection.
This should have continuity when the button is in the position of the door being open.
The next set of wires (three of them) power either of two coils of wire to move a metal rod that pulls the white slider up or down.
This slider can only move all the way up if the latch is in the closed position. This is because there is a long metal piece that is spring loaded to block it, when the latch is closed, it allows the white slider to move up. This metal piece is also a guide for the lock mechanism and brings the latch to a metal pin that catches the back end of the latch to hold it in position. The white slider blocks the metal tab when the slider is up, from allowing it full movement of moving the latch away from the pin. If the the black tab or white slider was moved down, it allows room for the metal piece to pivot, move the latch away from catching the pin and when the latch is pulled, to unlock.
The next set of wires (four of them) check whether the slider is up or down. How it works is that if the slider is up, then the top two terminals are bridged on the inside and the bottom two are bridged on the inside, giving you continuity when completely locked. When the slider is down and the latch is able to move freely, then none of the terminals are bridged and there will be no continuity.
I am unaware of how much resistance you need in the door sensor or the electromagnet to slide the rod.
I can say though that you need continuity where described.
If you get no continuity on the upper two or lower two of the four terminals grouped together when the latch is locked and slider up, then there is your problem.
If you have no continuity at the door sensor's two terminals when door is in open position, this may be your problem, but you will need to know the range of ohms and test for this to confirm.
For the electromagnet, you will need continuity from the middle terminal to the bottom terminal and from the middle terminal to the top terminal, if there is none, it will not be able to energize and move the slider. You will need to know the ohms to verify if this is faulty or not.
I am sorry that I do not know the ohms needed.
Warnings:
Remember to have the machine unplugged when opening or working on it.
This information is from my own attempt at figuring out what could be wrong and it may be different than your machine and may not be entirely accurate or complete since I don't have any manuals.
I have not been trained to work on these or any other machines, but I am highly mechanically inclined, but give no warranties to this information. If you decide to work on your machine based on this information, you do it knowing this and I can not be held responsible for any damages or injuries.
Posted on Feb 07, 2010
  • 4 Answers
SOURCE: kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
Posted on May 03, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
GE Washer, Model GBVH5140HWW. Door seal failed and water in washing machine leaked into the base of the washing machine. Removed the front panel, replaced the door seal, dried up the water in the machine...
The seal is likely not installed correctly. What is happening is the latch for the lock is trying to hook and it is being blocked so it doesn't actually lock. After so many tries the machine goes into an abort mode where it washes out all the water and stands by for it to be fixed. If you put some pressure on the door (closing it) while it is trying to lock, it likely will lock and then run. It is basically an adjustment issue. It is also possible that something with the lock mechanism is broken or out of adjustment causing the leaking to begin with and that is actually the area that needs attention rather than replacing the door seal. Door seals rarely fail unless they are physically damaged somehow.
Jun 02, 2011 | GE WSXH208A Front Load Washer
Ge washer wcvh6260 ...... start/pause button flashes, won't start
Does the 'door locked' light come on? If not, check the switch and it's actuator (a pin that is part of the door latch).
Aug 22, 2009 | GE WCVH6260F Front Load Washer
I have a ge front load washer model wbvh6240hww. I have replaced the control board the water valve and when the washer is turned on it still does not get water. The screens are clean the water is turned...
Does the door lock when you attempt to start the washer?
If not, you might check the door sensor. The washer may not realize the door is closed.
Aug 09, 2009 | GE Washing Machines
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
