Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Elements do not heat to proper settings
Top and bottom ovens are 50 degrees off
  • Frigidaire Master
  • 19,396 Answers
If both elements are not working properly then the problem is either the temperature probe or the control board.
Replace the temp probe first.
Posted on May 21, 2009
Why isn't my oven working? After changing bake element and thermostat
Either the bottom element is defective or the wiring to it is not hooked up properly so it gets power and does its job ala the top element.
OR the control that is responsible for having power delivered to both elements is only sending power to the top element. Make sure you are not using the broil setting since that only activates the top burner.
Feb 03, 2016 | Ovens
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
I have recently moved into a new house and the oven settings on all three dials have been wore away and cant see which setting to use for cooking
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
Hope this helped.
May 24, 2010 | Electrolux EOB2610 Electric Single Oven
Oven not heating properly - 25-50 degrees off - do I look at the heating element or what do I do?
if its off but heats fully i.e. 500 degrees then check for a defective thermocouple or oven temp control not an element
Oct 26, 2009 | Ovens
Oven will not heat until you turn the heat up to 400 degrees
Your "Bake" element may not be working properly. It's the one in the bottom of the oven. Place a couple drops of vegetable oil on the bottom pan, and turn the oven on. During pre-heat, you should start to see those oil drops generate some smoke, IF the lower element is working properly. If it isn't - voila'.!! Problem is with the lower element / associated circuit.
Oct 02, 2009 | Amana AOCS3040SS Electric Single Oven
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
124 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
