How much is 1,000,000,000,000 - Office Equipment & Supplies
  • Office Equip... Master
  • 8,016 Answers
One thousand billions (US), known is some countries (US, Canada) as Trillion. Here is a link to a page that gives the names of the (named) large numbers.
http://www.jimloy.com/math/billion.htm
Posted on Jan 02, 2014
11 billion dollars divided by 50 thousand people
11 billion is 11 000 000 000.
50 thousand is 50 000.
We can divide top and bottom by 1 000 to make it a little cleaner and we get 11 000 000 divided by 50.
By long division we have:
___220 000___
50 ) 11 000 000
100
100
100
0
Good luck,
Paul
May 07, 2015 | Office Equipment & Supplies
I need activation key
000-000-000-000-000-000
Feb 12, 2015 | Computers & Internet
What services does Kia Sportage 2008 with 90000 need?
Here is recommended maintenance up to 10 1/2 yrs. If you follow through list, you should be able to tell by elimination what you may need. Here is the link - also list pasted below, here:
http://www.kia-forums.com/2g-2006-2010-rio-rio5/35574-maintenance-schedule.html
SUGGESTED Maintenance Schedule:
Months Kilometres Maintenance Type
4 months 6 000 km Maintenance #1
8 months 16 000 km Maintenance #2
12 months 24 000 km Maintenance #1
16 months 32 000 km Maintenance #3
20 months 40 000 km Maintenance #1
24 months 48 000 km Maintenance #2
28 months 56 000 km Maintenance #1
32 months 64 000 km Maintenance #3
36 months 72 000 km Maintenance #1
40 months 80 000 km Maintenance #2
44 months 88 000 km Maintenance #1
48 months 96 000 km Maintenance #3
52 months 104 000 km Maintenance #1
56 months 112 000 km Maintenance #2
60 months 120 000 km Maintenance #1
64 months 128 000 km Maintenance #3
68 months 136 000 km Maintenance #1
72 months 144 000 km Maintenance #2
76 months 152 000 km Maintenance #1
80 months 160 000 km Maintenance #3
84 months 168 000 km Maintenance #1
88 months 176 000 km Maintenance #2
92 months 184 000 km Maintenance #1
96 months 192 000 km Maintenance #3
100 months 200 000 km Maintenance #1
104 months 208 000 km Maintenance #2
108 months 216 000 km Maintenance #1
112 months 224 000 km Maintenance #3
116 months 232 000 km Maintenance #1
120 months 240 000 km Maintenance #2
124 months 248 000 km Maintenance #1
128 months 256 000 km Maintenance #3
MAINTENANCE #1
MAINTENANCE #1 INCLUDES:
Replace engine oil and filter
Check fluid levels (pwr. strg., brake/clutch, coolant, washer)
Check tire condition and pressure (including spare)
Check exterior & interior lights for proper operation
Check windshield washer/wiper function
Check horn function
Check handbrake function/freeplay
Lubricate all latches, hinges and locks
* = if equipped
See "Model-Specific Maintenance"
MAINTENANCE #2
MAINTENANCE #2 INCLUDES:
Check horn function
Check engine coolant specific gravity
Check engine air filter; knock out dirt/bugs, replace as req'd
Remove wheels and brake drums, check pad/shoe thickness; inspect calipers, cylinders and shoes for proper function, leaks or damage; adjust rear brakes as required.
Rotate tires
Visually check underbody fasteners for condition & integrity
Check brake/clutch pedal freeplay
Check steering wheel components for proper operation
Check CV boots/tie rods/ball joint boots (visual inspection)
Check all seat belts and anchor integrity
Check exhaust sys. for leaks, mountings, brackets; heat shield
Check transfer case oil level & condition, fill as required
Check front & rear differential fluid, fill as required*
Check man. transaxle oil level & condition, fill as required*
Check auto transaxle fluid level & condition, fill as required*
Lubricate driveshaft u-joints (early Sportage only)
Road test vehicle
* = if equipped
MAINTENANCE #3
MAINTENANCE #3 INCLUDES:
Check horn function
Check coolant specific gravity
Inspect, deglaze, clean, adjust & lubricate brake components
Rotate tires
Check transfer case oil level & condition, fill as required*
Check idle speed
Inspect power steering lines & hoses (visual)
Check A/C compressor operation and performance*
Check brake line fittings, bleeder screws, booster for damage, looseness, leaks
Road test vehicle
* = if equipped
KIA MODEL-SPECIFIC MAINTENANCE
In addition to the KIA Basic Scheduled Maintenance, certain KIA Models will require the following maintenance services:
ALL MODELS
(Every 36,000 km or 18 months)
Manual transaxle service (except Sportage)
Automatic transaxle service (except Magentis)
Check drive belt condition & tension
Inspect front ball joints
ALL MODELS
(Every 48,000 km or 24 months)
Replace engine coolant
Replace engine air filter
Inspect fuel lines & connections
Inspect ignition wires
Replace spark plugs (except Platinum)
ALL MODELS
(Every 60,000 km or 30 months)
Replace brake/clutch fluid
Inspect EVAP canister & vapour lines
ALL MODELS
(Every 72,000 km or 36 months)
Replace fuel filter
Inspect PVC system/hoses for integrity
ALL MODELS
(Every 96,000 km or 48 months)
Replace spark plugs (Platinum)
ALL MODELS
(Every 102,000 km)
Replace timing belt
SPECTRA
(Every 12,000 km or 6 months)
Replace HVAC air quality filter (if equipped)
MAGENTIS
SPORTAGE
Transfer case, differential & manual transaxle service
Transfer case & differential service (auto. trans. model)
SORENTO
Jul 16, 2014 | Kia Sportage Cars & Trucks
Convert $8 000 000 per mile to $ per kilometer
There are 1.609344 km in a mile. So, the following statement is true:
$8 000 000 = 1.609344km
Now bring it down to One km, rather than one and a decimal by dividing both sides of the equation by 1.609344.
8 000 000/1.609344 = 1km.
You wind up with the following:
$4 970 969.5378986717569394734749065 / 1km.
(obviously, round it to a normal dollar figure, rather than to hundredths of thousandths of cents)
You wind up with $4 970 969. 54 per kilometer.
Feb 18, 2011 | Texas Instruments TI-83 Plus Calculator
Trying to find the owners manual for 2001 saturn sc2 as well as the maintenance schedule etc provided when the car was new
Scheduled Maintenance The service shown in this schedule up to 150,000 miles (250,000 km) should be performed after 150,000 miles (250,000 km) at the same intervals.
See Owner Inspections and Services for maintenance information.
Scheduled Maintenance Mileage
Maintenance Group No.
6,000 Miles (10 000 km)
18,000 Miles (30 000 km)
30,000 Miles (50 000 km)
36,000 Miles (60 000 km)
42,000 Miles (70 000 km)
50,000 Miles (83 000 km)
5
54,000 Miles (90 000 km)
60,000 Miles (100 000 km)
6
66,000 Miles (110 000 km)
72,000 Miles (120 000 km)
78,000 Miles (130 000 km)
90,000 Miles (150 000 km)
7
100,000 Miles (166 000 km)
8
102,000 Miles (170 000 km)
108,000 Miles (174 000 km)
114,000 Miles (190 000 km)
120,000 Miles (200 000 km)
6
126,000 Miles (210 000 km)
138,000 Miles (230 000 km)
150,000 Miles (250 000 km)
5
Maintenance Requirements - Group 1 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). Maintenance Requirements - Group 2 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Inspect the engine accessory drive belt and coolant hoses every 12 months or 18,000 miles (30,000 km), whichever occurs first. Maintenance Requirements - Group 3 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Replace the engine air cleaner filter every 36 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Inspect the vacuum lines/hoses every 24 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Replace spark plugs. An Emission Control Service.
Oct 05, 2010 | 2001 Saturn SC
Total space problem. i have a buffalo turbo usb ministation 160GB but when i open my computer it has only a total size of 149GB...how to make it 160GB?......please help
The windows use some space for space addresing but not that much
It shoves 149 GB because manufacterers use the terms gigabyte in metric (base ten) way.
IT means 160 GB = 160 * 1000 MB = 160 000 * 1000 KB= 160 000 000 * 1000 Bytes
when you convert that in Gigabyte that computer use (1GB = 1024MB, 1MB = 1024 KB, 1 KB = 1024 Bytes) you get:
160 000 000 000 Bytes = 160 000 000 000 /1024 KB = 156250000 / 1024 MB = 152587,890625 / 1024 GB = 149,011 GB
Jun 18, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
How do i change L to mL on the casio fx-115es
The scientific prefixes are
  1. Giga = 1 billion ( times 1 000 000 000)
  2. Mega = 1 million (times 1 000 000)
  3. Kilo = 1 thousand (times 1000)
  4. deca = 10 (times 10)
  5. deci = one tenth ( divided by 10) or multiply by 0.1
  6. centi = one hyndredth (divide by 100) or multiply by 0.01.
  7. milli = one thousandth (divide by 1000) or multiply by 0.001
  8. micro = one millionth (divide by 1 000 000) or multiply by 0.000 001
  9. nano = one billionth (divide by 1 000 000 000) or multiply by 0.000 000 001
So 1 milliliter = 1mL = 1L/1000 = 0.001 L
1L = 1000 mL
It is instructive to learn the meaning of these prefixes, because they always mean the same thing, regardless of the units you are dealing with.
Ex: The population of the Earth is about 6 Gigapersons (It does not exists, but it illustrates the principle. I hope you win a jackpot of 10 megadollars. (M$)
Hope it helps.
Nov 17, 2009 | Casio FX-115ES Scientific Calculator
New Laptop keeps shuting down with Error message
I recommend that you don't bother trying to fix this problem yourself.
Seeing as the laptop is new it will be under warranty, take it back to where you bought it or phone the manufacturer to arrange for it to go in for repair.
Tell them that you are getting the "blue screen of death"
They will either repair or replace the laptop free of charge and you won't have to pay courier charges either.
Regards.
Nov 13, 2009 | Gateway Computers & Internet
My new laptop keeps shuting down with a Blue screen with the foll. message, please advise, I'm thinking about returing it to the Dealer in NY, Im in Jamaica: Problem Event Name: Blue Screen OS Version:...
This error comes because of windows file missing and virus in the system so i advices you to take backup of your system and reformat the operating system.
Nov 12, 2009 | Office Equipment & Supplies
54 people viewed this question
k24674
jasbo
jasbo
