Question about Kitchen Ranges
Dayton portable heater 3ev52 - Kitchen Ranges
3 Suggested Answers
  • 1015 Answers
SOURCE: Need parts for Dayton Ultra Portable Heater Model
I would cotact Grainger industrials supplies by callig 1-800-323-0620. Or e-mail at Grainger.com I have dealt with this company for 25 years and I've always been happy to do business with them. Hope this helps you. You will need name brand,part description,and part no. if possible.
Posted on Nov 18, 2010
SOURCE: Dayton 3VE59 Gas Utility/Portable Heater won't
Just repaired one of these, problem was that main gas valve was not opening, valve is controlled by a vacuum switch, vacuum is created as fan blows air down tube past bent up metal flap near front bottom of heater (slight low pressure zone created). If vacuum switch is miss adjusted it will not close when fan is running and no gas flows. this is easy to check as vacuum switch also has a pressure port on it. With gas disconnected, remove bottom cover, locate vacuum switch (it has a hose clear plastic hose connected to it, in opposite corner is another hose connection, attach a length of hose to it that you can blow lightly into. With heater plugged in and no gas connected (USE CAUTION OF WIRE!!!), turn heater on you should hear after a few seconds the ignition and then a loud click as the gas valve opens, if no click blow lightly into end of your added tube, if you now hear a click the gas valve just opened. if you stop blowing you might hear the gas valve click again as it re-closes. If this is the case the vacuum switch needs to be adjusted slightly. THIS switch is hear for your safety, Adjust at your own risk!!! This can be done with a screw drive in the top, rotate screw slightly while checking if the fan alone causes enough vacuum to make the switch work. DO NOT over adjust. check safety operation before hooking up gas by placing a piece of cardboard or wood over the air intake and the exhaust to block airflow, if the air flow is blocked you should hear the gas valve drop out and reconnect as air flow is reestablished. Hope this helps
Posted on Feb 13, 2011
I need a wiring diagram for a dayton 1rkt5a portable heater
Call Grainger with the model and serial number. Hopefully they can help you
Jan 16, 2018 | Dayton Heating & Cooling
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
I have a Dayton 3ve50 portable oil heater. I am using diesel, it will run with the cover off. when I put the cover back on I get a #51 error message and the heater shuts off.
You need to make sure the pressure gauge is reading at least 5.5 psi of pressure.
Wit Diesel typically we would go to 6.2 -6.5psi of pressure to help with starting and cleaner burning.
If you need technical service you can find us online at www.msservice.net
Jan 02, 2015 | Dayton Heating & Cooling
I am having trouble getting my Dayton Portable Oil fired Heater Model # 2E218E to keep running.
May be the primary control if you already replaced the photocell. Make sure the photocell is in direct line of sight with the flame.
Jan 04, 2014 | Dayton Heating & Cooling
Need parts for Dayton Ultra Portable Heater Model 1VNX6A I need a source for parts
Nov 18, 2010 | Dayton E48 Oil Filled Utility Heater
I need a service manual for a Dayton oil fired 350,000 BTU heater.
I have a manual for a Dayton 3E218E. If you want a copy email me at Edwards0202@aol.com and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well:
http://www.bealsmotor.com/
Nov 30, 2009 | Dayton E50 Heater
Heater will not light
It doesn't seam to get fuel. It may be as simple as a clogged fuel filter.Try cleaning the filter or replace it.
Apr 12, 2009 | Dayton E48 Oil Filled Utility Heater
I have a Dayton E48 heater that is in disrepair
portable heater parts.they have an on line service and parts. www.portableheater.com
Jan 30, 2009 | Dayton E48 Oil Filled Utility Heater
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
