Question about Nikon Science & Laboratory
Nikon smz-2t is blurry between the lenses - Nikon Science & Laboratory
Can a cracked lense be replaced?
Go on Nikon's website and find the nearest Nikon Service Center. They can give you a price. However, my educated guess is that will probably cost considerably more then the camera is worth.
Jul 04, 2014 | Nikon COOLPIX S230 Digital Camera
New nikon d5100 blurry when taking pictures using 18-55 mm vr lense
do you have it set on automatic focus and if so you may have a bad lens
push shutter buton half way down when select in auto it will focus it for you if that don't work send lens in
Jan 30, 2013 | Nikon D Cameras
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
My nikon d3100 is saying error press shutter release button again and it dont do nything.. it also has a dark blurry film when i look through the lense ?
Hey Julie,
We'll solve your problem in a moment.
Step 1,
First, I need you to look through the viewfinder, and press the shutter release button, half-way, and notice the difference. Don't let go, till you hear a beep sound. The blurriness that you see will clear automatically.
If you hear no noise, and the blurriness doesn't go, try this.
Step 2,
On the lens, there will be a tiny button. It'll have A-M on it. Switch it to 'A', if not already on it.
Once you do that, try step one again. Now, you'll be able to overcome your problem.
Toodles,
Rebel!
Sep 18, 2011 | Nikon D3100 Digital Camera
In the middle of taking pictures, all of a sudden my Nikon P100 will become blurry and then the Lense Error message will come up saying, "Lense Error: if the lense cap is on the camera, turn the...
Could be sand particles getting into the seams around the lens barrel, binding it up. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 08, 2011 | Nikon COOLPIX P100 Digital Camera
I have Nikon Coolpix S80000. It becomes blurry when I use the telephoto lense and for night photos too. What settings should I have it on to avoid this? Anne
You could raise the ISO or better yet, use a tripod. In dim light and when using telephoto, the camera uses a slower shutter speed and any movement from you results in a blurry picture.
Apr 12, 2011 | Nikon COOLPIX S8000 Digital Camera
I JUST got a Nikon Cool Pix L22 but no matter what setting I use EVERY picture is blurry. I am an art teacher and understand shutter speed and aperture, I even used a tripod. The pictures are still...
Most likely your fisheye lens attachment is out of alignment. An internal element may have come unscrewed or unglued. The other option (I'm assuming you have already checked this) is that it is incorrectly attached to the camera - check your threads and make sure it wasn't cross threaded and that there are no blockages to the lens attachment being screwed in completely. If the fisheye lens is not in the correct position relative to the CoolPix lens, then the pictures will be blurry.
Nov 21, 2010 | Opteka Full Fisheye Lens for Nikon Coolpix...
Blurry, AF not working
Try resetting the camera to it factory condition ..... also open lens and clean the contacts...and then try
Oct 12, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Blurry photos
good day,
have you tried adjusting the focusing of your lense? what i mean with this is by manually rotating the lense of your camera.
try readjusting your lense until you achieve your desired focus.
i hope this helps
Sep 20, 2008 | Nikon D50 Digital Camera
Science & Laboratory Logo
107 people viewed this question
Top Nikon Science & Laboratory Experts
matt
matt
William McMath
Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
