Question about Miele S558 Red Velvet Bagged Canister Vacuum
Zanussi ZAN1829 1800w stopped working while cleaning
A Zanussi multicyclonic hoover will no longer pull bits from carpet despite having very strong suction
make sure that rotating brush is clean. They oftem get clogged with material and then need cleaning. scissors are an easy way to make it easy.
Jul 16, 2016 | Hoover Vacuums
Bissell proheat cleanshot 2x won't stop putting out cleaner and water, the little dial won't stop spinning
First clean the Flow Indicator filter. Turn the Flow indicator cap counter-clockwise to remove it. Lift the rotor and the filter under it out. Clean the filter and reinstall in reverse order. Make sure you have unplugged the unit before working on it. Then clean the lint filter on the heat tank cap (it looks like a screen) and reinstall it. There's not much more to these so if that doesn't work call the Bissell Consumer Care at 1-800-237-7691
Oct 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a light weight shark navigator vacuum it just stopped working help
Unfortunately these where designed to fail. I owned one, I could take it apart and clean everything and make it work again, eventually it stopped working completely tho
Feb 21, 2015 | Shark Vacuums
Beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Mar 07, 2009 | Singer Vacuums
Roomba keeps saying clean brushes yet are clean!
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Epic 6500 vac stopping for no reason
Could have a problem with the cord or the motor.
Apr 20, 2008 | Electrolux Epic 6500 Vacuum
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Miele S558 Red Velvet Bagged Canister Vacuum Logo
22 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
