Question about Coby Kyros 716829701508 Tablet PC
My coby kyros mid7014 has gone to FWDN mode, how can I change it?
I tried to reset to factory condition and now it says going into DWDN mode and will not respond
  • 76 Answers
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Posted on Feb 28, 2011
  • 14 Answers
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Posted on Apr 08, 2011
  • 274 Answers
SOURCE: coby kyros factory data reset
It's better to contact the supplier for tech help, because I didn't have this tablet before.
Android 4.0 Tablet PC
Posted on Feb 07, 2012
  • 274 Answers
SOURCE: How do you find the IMEI/MEID# on the Coby Kyros 7022
In the main screen, press Menu> Settings> Tablet PC> Tablet PC recognition,To display the IMEI / the MEID and phone number of the Tablet PC.The IMEI (International Mobile Equipment, Identity) is used to identify a GSM mobile phone number.The number of the MEID (Mobile Equipment, the Identifier) is used to identify the CDMA Tablet PC.
  • 4961 Answers
SOURCE: My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Posted on Aug 19, 2012
What do I do to my next book Ares 8 ? Every app I open says not responding?
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the tablet.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet. how do you rest nextbook tablet
Jan 07, 2018 | Tablets & eReaders
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    MID model M729B can not get the tablet to respond to unlocking the screen
    Here's a link to the manual:
    http://www.mymidpad.com/M729B_User%20Manual.pdf
    You need to do a hard reset which will wipe all data and restore the tablet to factory settings.
    Jan 18, 2015 | Tablets & eReaders
    I have tried all of the suggestions in the forum including a factory reset but my Toshiba Excite Tablet remains in safe mode. How do I remove the tablet back to normal mode?
    Most likely it is dead. If you tried a real factory reset, then just look for another tablet. Toshiba is not going to help you as, from my experience, they do not care after they sell you the prodcut and it gets out of warranty.
    Consider Samsung.
    Dec 24, 2014 | Toshiba Excite 10 16GB 10.1" Capacitive...
    Letter 'B' doesn't work on my keyboard!!!!!
    You could try re-calibration, or reset the device, or restore device factory settings as per the below 3 options. There is also a link at the bottom to a user guide. If that doesn't work, you probably have a faulty touch screen, in that case return the device to the place of purchase for warranty repair/replacement:
    Q: G-SENSOR is not responding.
    A: You should calibrate your device using 'Settings' / 'Display' or Gravity Calibration App (optional).
    Q: My GOCLEVER tablet does not react well, it is freezing, works much slower than normal or does not respond at all.
    A: We recommend to restart your device using turn on/off button (pressing 3-4 sec) or reset button (with a pointed object).
    Q: How do I restore factory settings?
    A: You should use 'Factory reset' function available in the 'Settings' App. The factory reset will help if your application causes the inappropriate operation of your device. Note, that all your files will be lost, so we suggest to copy them to another device (pendrive, PC etc).
    http://1palladium.com.ua/load.php?f=goclever-terra-101.pdf
    Oct 13, 2014 | Tablets & eReaders
    Hw do i reet my tablet
    Try to reset your tablet to its factory default mode. To do this, follow the steps on the video provided below.
    Sep 24, 2014 | Hannspree SN10T1 101 Tablet
    What do I do when my surface tabnlet will not turn on.
    Sounds as though the power has gone. Try plugging in the power then start it up..
    Aug 02, 2014 | Microsoft Surface RT
    My nook tablet by barnes and noble wont come out of demo mode
    You'll have to factory reset it by turning it off and holding the home button and power button at the same time I know because I got into my hidden setting and accidently turned it on myself
    Jan 08, 2013 | Barnes & Noble Nook Tablet
    My apps libaray on my coby kyros mid7015 isnt working!!! everytime i try to go into the apps libaray it keeps saying that theres been an unexpected problem and that it has to "force close" why is...
    Go to Settings.
    Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
    Coby Kyros 716829701508 Tablet PC Logo
    62 people viewed this question
    Top Coby Tablets & eReaders Experts
    Martin Murray
    Owen Barnes
    Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
