Question about Dell Computers & Internet
Mini one 57 - Dell Computers & Internet
  • 979 Answers
Whats your inquiry?
Posted on Jan 03, 2014
We have a 57 mini cooper s that has a fault code 2880, can you tell me what this is ?
well you learn something every day. I was not aware that mini vehicles had computers in 57.
to get on with it code p2880 refers to air leak/blockage between air filter and mass air flow (MAF) sensor===causes--mechanical fault
check for something loose broken out or missing or a blocked air filter.
Feb 25, 2015 | Mini Cars & Trucks
Mini Cooper 57 reg wont start
if you have spark and gas the only other things you need are compression and timing- cheers Denny
Dec 21, 2013 | Mini Cooper Cars & Trucks
My oasis he is not a see through top but i keep getting the ul message and when it goes through the spin cycle it sounds like ajet engine. iS THERE A SENSOR THAT NEEDS REPLACED.Sears wants 129.00 to just...
UL is unbalance load. uL is displayed when the machine/motor control detects an
off-balance load, and is steady on while the washer runs a
mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the
load.If the mini-cycle is unsuccessful, uL will flash until the door
lid is opened, allowing the customer to view and
redistribute the load. Page 57 shows the suspension
rod removal to get the tub out. These rods (4) hold the tub in place. Sorry I do not have an oasis manual but this Bravos manual will give you an Idea. One of those rods could be worn to the point it is throwing the the whole tub off. If a rod is broken then the tub could be pressing against the base and binding the motor, causing that noise. You gonna have to check and see.
Nov 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Where are the fuses for the lighter and accessory plugs
THE FUSE YOU ARE LOOKING FOR IS #63 POWER POINT, INSTRUMENT PANEL, CIGAR LIGHTER FRONT AND IT IS A 20 AMP FUSE. #66 IS POWER POINT, C PILLER, REAR AND IS ALSO A 20 AMP FUSE BUT NOT FOR THE FRONT INSTRUMENT PANEL. #S 57 & 61 ARE LISTED AS NOT USED. THESE FUSES ARE LOCATED IN THE FUSE BOX IN THE ENGINE COMPARTMENT. THEY ARE ABOUT 3 ROWS OF FUSES FROM THE BACK OF THE COMPARTMENT COMING TOWARD THE FRONT. THEY WILL BE MINI FUSES IN THE MIDDLE OF THE FUSE BOX AFTER THE FIRST 3 ROWS OF FUSES FROM THE BACK OF THE FUSE BOX TO THE FRONT WHERE YOU WOULD BE STANDING. THEY WILL HAVE 4 MINI FUSES TO THE RIGHT OF THEM AND 4 TO THE LEFT. IF THEY ARE LABLED THEY WILL BE 66 AND 63. YOU WANT 63 WHICH WILL BE CLOSEST TO YOU.
Apr 06, 2010 | 2005 Ford Freestar
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
2006 bmw 325i remote only unlocks driverside door. will not unlock all doors when you lock it from the inside. have to use key in remote to open door. also central button to unlock doors is inop
fuse 56 and 57 control central locking,the issue is caused by surges typically in the front door lock actuators, normally at a dealer they would replace fuse 56 and 57 with a 20a mini fuse and if still occuring repl the door lock(s) that dont work or typically both front, first replace fuse 56 and 57 with 20a fuses as were too small from factory and than operate ten to 15 times, if it doesnt work at first dont panic,let the car go to sleep which takes about 16 min and than try again this problem has nothing to do with the key fob or the lock unlock button inside,also the fuses are located behind the glove box just rere the access panel and they are found at lower left section
Jul 23, 2009 | 2006 BMW 3 Series
Which HP printers use #56 & 57 cartridges ?
Fits Models: Deskjet 450cbi ... 1350 PSC ( 57 56 HP C6657AN Ph C6656AN 57 56 HP C6657AN Ph C6656AN 57 56 HP ....
Hope this helps. Bud
Jan 09, 2009 | HP DeskJet 5150 InkJet Printer
Capacitors for Toshiba Hyper box
Yes it will take care of numerous problems. Replace all 10mfd caps on the board.
Dec 11, 2008 | Toshiba 57H81 57" Rear Projection...
50h72 toshiba big screen
It's in the hyper module and you need to have replaced several small smd capacitors 16v/10mf with some mini camcorder caps is easiest.
Bill
Oct 31, 2008 | Toshiba 57H82 57" Rear Projection...
Computers & Internet Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
