Question about HP Compaq dx2000 Microtower PC Desktop
Fan cpu not working - HP Compaq dx2000 Microtower PC Desktop
My CPU Heat
You should check Task MGR and see what process's are running, you need to find out if the CPU is being pushed, when you are not doing anything the CPU should be close to zero or between 0-10 percent.
So if you check and find the CPU is running at Idle, then you check the CPU fan clean it.
You should install software that will show you the CPU temp and fan speed, as you work the CPU through software running, the fan should increase in speed.
If the CPU is not staying cool near 40C, then look for a better cooler.
Thermal compound has no miracle, the cooler is what is important, and the case fan is not as important as the CPU cooler itself.
Dec 02, 2012 | Computers & Internet
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
880GMA-E45......my cpu fan system not functioning,,,how to troubleshoot the error?..pls advice..
Try plugging the CPU fan into one of the other fan ports on the motherboard. If the fan still does not work, then the fan is bad. If it does work then the circuitry that controls the cpu fan speed is bad. You can try turning off speed control in BIOS and see if the fan works again in the cpu fan plug.
Jim
May 10, 2011 | MSI Computers & Internet
Why Dell Laptop cpu fan are first time power on can work but after boot process can't work?
Maybe you are interested in this:
http://www.laptopcpufan.com/dell-laptop-cpu-fans-c-1.html
Jun 15, 2010 | Dell (H5195) Laptop Cooler, CPU Fan,...
Cpu fan can not detect when boot at hp dx 2300
YOUR CPU FAN MIGHT BE VERY DIRTY OR IS NOT WORKING. YOU MAY CLEAN THE FAN AND HEAT SINK. AFTER CLEANING AND YOU TURN ON THE THE PC AND THE FAN DIDN'T WORK YOU CAN BUY THE CPU FAN TO A ELECTRONIC STORE SUCH AS FRY'S ELECTRONIC'S. HOPING THIS INFORMATION WILL HELP YOU SOLVE CPU FAN PROBLEM.
Aug 14, 2009 | HP Hewlett Packard Compaq dx2400...
CPU fan not detected
replace ur cpu fan...... if u hv a problem with SMPS the fan which u can see at the back of ur cpu do replace it.. this SMPS provides all the power requorements for ur CPU
Jun 29, 2009 | Computers & Internet
MLTIPEL PROECESS EROOR
sounds like your fan on your cpu is almost taken a dump common prombelm you better change it before it over heats and takes your cpu out ... lala linda
May 14, 2008 | Dell Delta Electronics CPU Processor Fan...
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
My 4-pin cpu fan is not running
check the power connection for your mother board and fan
Mar 09, 2008 | Computers & Internet
HP Compaq dx2000 Microtower PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
