Question about Sony DAV-SC8 System
No power when i turn on. The standby light flashes once and nothing else happens. No display or functionality at all
The stanby light flashes twice when i hold the power button in and switch on.
    New Friend:
I have a DAV-s880, worked properly, till powerfail. Will not start up. Standby light is blinking (continues blinking)
Posted on Apr 07, 2016
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Seem like you need a battery
Posted on Jan 03, 2014
4 Suggested Answers
SOURCE: blinking standby light on my Sony DAV-C770 when powered on, black display screen
The audio amplifier IC of your device are damaged you gotta change it,or send it to a repair center .
Posted on Jun 05, 2008
welcomejee
  • 10594 Answers
SOURCE: The standby light is blinking and the system is not functioning. Can you help?
Unplug unit from AC power outlet for 5 minutes, plug it again and check.
Need further help, let me know.
Posted on Oct 13, 2008
SOURCE: Flashing standby message.
I have a Sony home theater DAV-S800 is blocked appears standby and power button just turns on a red light, green light and not to do, thanks for your help
Posted on May 11, 2011
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Stanby light flashes red. System will not turn on. Trouble shooting does not work
Have you tried unplugging the power supply cable. Wait a couple of minutes then plug it back in. See what happens.
Or HOLD steady the standby button for a couple of seconds and release it once you see the color change to blue. Hope it works.
Jun 24, 2010 | Philips HTS6515D Theater System
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
Onkyo ht-r670 receiver is new and will not turn on. red standby light is on. but no display. also remote doesn't have any effect.
I would check any fuses first. The power transformer could also be open.There is a stanby supply that provides 5 volts that is always on . This is what supplys voltage for the standby light and the cpu. When you press the power button the cpu trips the power on relay that provides the 120v ac to the main transformer. If the transformer is open nothing happens. Onkyp part # is 2301798. Check the windings for continuity.
Dec 31, 2009 | Onkyo Audio Players & Recorders
Hi thanks for replying
The clicks you are referring to sound like High Voltage Leaks or Arcing. While it is clicking check for sparks around the high voltage transformer only with your eyes from a distance. If you see sparks shut it off immediately.
Dec 29, 2008 | Philips 42PFP5332D 42 in. Plasma...
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Oct 13, 2008 | Sony DAV-C770 System
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony DAV-SC8 System Logo
330 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
