Question about Kenwood KDC-X591 CD Player
Mi estereo kenwood kdc-248u aparece protect - Kenwood KDC-X591 CD Player
SOURCE: protect mode
Press reset button (small circular button need something with a point) to the left of the 1 channel
Posted on Feb 28, 2009
SOURCE: how can i deactivate the protect that blinks in my
Disconnecting the terminal will take to much time.. In between the skip button ,and the #1 on your stereo there is a little dot. Barely noticable unless you know what your looking for, take a safety pin or a screw( anything with a little tip) and push it in. This will restart your stereo. (Car Must be on)
Posted on Feb 12, 2010
  • 40 Answers
SOURCE: Kenwood kdc-bt742u flashing protect and no sound
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Posted on Mar 25, 2010
  • 12 Answers
SOURCE: kenwood kdc-mp208 stuck in
Protect indicates that there is a short or a grounding problem usually within the speakers2_bing.gif or the speaker wiring. Locate and press the reset button (pinhole). If protect comes back then disconnect all speakers, reset and connect them back one at a time until protect shows up again. This will help you find out where the unwanted DC signal is coming from. If protect shows up when all speakers are disconnected, then it may need service.
Posted on Apr 13, 2010
SOURCE: kenwood kdc-mp442u protect mode came
First of all , your Kenwood shows only Protect on the display when your speakerwires are conflicting with each other , but when you cannot find the problem there....
disconnect them one by one to see wich speaker in your car is conflicting (shortcuts).
Replace that speaker and your kenwood will work just fine.
I had the same problem here with a brand new Clarion speaker .
Posted on Oct 20, 2010
Compr? un Radio Kenwood KDC-X300,cuando programo la hora,la fecha,dem?s funciones,apago mi carro,lo vuelvo a prender,el radio aparece en standby┬┐?lguien de ustedes me podr?a dar una respuesta?
Mi Espa?ol no es my biene ,perdone. Suena Como que lo tiene connectado all ignition solamented. Se nececita conectar el alambre de Acc. A la batteria directamente Para que Guarde la memeoria . Ay beses que se Idica el alabre en question con color azul. Hope it helps Buena suerte,
May 16, 2016 | Cars & Trucks
En mi estereo Pionner aparece de repente en la pantalla AMP ERROR , porque es ?
I do not speak/read Spanish, but via Google translator, I understand your Pioneer is in protection mode? This indicates a shorted speaker.
Yo no hablo / leer espanol, pero a traves de traductor Google, entiendo su Pioneer esta en modo de proteccion? Esto indica un altavoz en corto.
Dec 20, 2013 | Clarion CZ209 Car CD/ MP3 Player
COMO QUITAR PROTECT ESTEREO KENWOOD KDC-MP642U
En estos modelos quedan grabados los errores de DC en el eeprom y se tiene que limpiar y estos son los pasos para este modelo:
Mientras que el display muestre PROTECT presiona el y sosten el 3 y 6 y luego presiona el RESET mantelos presionados por unos dos o tres segundos y luego suelta el RESET y despues de uno o dos segundos suelta los otros switches.
El display debe mostrar:
DC ERR
Presiona el 1 y el display mostrara
DC1 ERR
Presiona el 1 y sostenlo por par de segundos y el display mostrara
DC1 OK
Presiona el 2 y el display mostrara
DC2 4
Presiona el 2 y sostenlo por un par de segundos y el display mostrara
DC2 0
A este punto el eeprom ya esta limpio y nada mas presiona el RESET y el disply debe mostrar STANDBY
Espero que esta informacion te sea util y avisa si te funiona
Suerte y saludos
Jan 27, 2013 | Kenwood KDC-MP642U
Why does stereo say protect
Check if a speaker wire come off or some other wire, That will cuase it to go into the protect mode,Allso if you have a amp hooked up to it, End continully have the music cranked up the system will over heat ,That can cause it allso to go into protect mode, There is a reset button on the face plate but it is not marked,
Nov 02, 2012 | Kenwood KDC-248U In-Dash CD, MP3, WMA Car...
Codigo para desbloquear estereo kenwood kdc-mp442u
Mi estere tiene bloqeadas toda las funciones eseto el volumen q puedo aser
Feb 19, 2012 | Car Audio & Video
Por que aparece la palabra protec en mi auto estereo
ese error se ignifica un corte a tierra en las lineas de bosinas o impedencia muy baja (< 3 ohm). el estereo apaga el amplificador interno para proctejerlo.
Mar 04, 2011 | Kenwood KDC-MP238 CD Player
Necesito el code,pero no tengo control remoto.
Hola zubiate712,
Usted puede comprar el teledirigido en línea del almacén accesorio de Kenwood.
El número de modelo para su KDC-MP235 es RC-557 y el coste es el envío más $9.75.
Espere que esto ayude.
May 26, 2009 | Kenwood KDC-MP235 CD Player
How do you reset this deck
There is a reset button on the left front of the deck>
Feb 16, 2008 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-X591 CD Player Logo
87 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
