Question about Toshiba Excite 10 Tablet
Excite 10 will not turn on
Worked beautifully, took break, put it in it's tight sleeve to stand it up now nothing. running on AC so power not issue. It was off when I put it in it's Toshiba cover, flashed on went off, now nothing.
2 Suggested Answers
mike0862
  • 5651 Answers
SOURCE: my toshiba excite 16gb 10 hd sku:7360TT2 it wont let me connect to wi-fi what can i do i factory reset nd nothing
The solution is a factory reset....I know you mentioned you have done this but did you follow this method?
1.Make sure the tablet is off and not in standby.
2.Hold down the 'Volume Up' and 'Power' buttons simultaneously until the two Android icons appear.
3.Use the volume buttons to select the white box on the right.
4.Once selected, press the power button.
5.Use the volume buttons to select 'wipe cache partition' and then press the power button.
6.Select 'Yes' and press the power button.
7.Use the volume buttons to select 'wipe data/factory reset' and then press the power button.
8.Select 'Yes' and press the power button.
9.The tablet will now reset.
Posted on Feb 05, 2015
I dropped it on the bathroom floor. I didn't break, but wont come on. I took it apart and nothing is broken and everything is attached
Held power button down for a good 5 seconds after putting battery back in?
Plugged it in to be sure it has a charge?
Take it in to a best buy or carrier store just to be sure.
Also, Something internal may have broke. Not visible but enough to keep screen from lighting up.
Do the soft keys light up?
Sep 22, 2015 | Tablets & eReaders
My toshiba excite 16gb 10 hd sku:7360TT2 it wont let me connect to wi-fi what can i do i factory reset nd nothing
Feb 04, 2015 | Toshiba Tablets & eReaders
How do I do a firmware update on android notebook?
I don't see have the steps you were given, (let battery get very low then get an SD card) is going to do anything to fix this. Without knowing the make and model there's not a lot to go on. What version is it running? Jelly Bean? Kit Kat?
Have you done a reset? Holding the power button in for 10 seconds until it shuts down completely? I'm not sure that doing a firmware upgrade is going to fix this. If you can get the tablet to run long enough you could try it, but if it freezes up in the middle of it, you could break your tablet.
Oct 07, 2014 | Tablets & eReaders
What charger do i use for a toshiba excite pure tablet
you do not say which version of Excite tablet you have, but this might get you going in the right direction:
Toshiba 10W Global AC Adapter for Excite 10 SE Excite Pure and Encore...
Oct 03, 2014 | Toshiba Tablets & eReaders
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
Why won't my screen turn
There's a switch on the side that you have to flip. If that doesn't work, try rebooting the tablet.
Oct 27, 2013 | Toshiba Excite 10 Tablet
Do not have the pin to unlock my toshiba excite 10 tablet what is the code
Factory reset is the only answer;
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
Jan 08, 2018 | Toshiba Tablet. Excite 10.1 in. Android...
When I turn on M275 I get power light, hard drive
I have the same M275 tablet and was looking for a solution when I came across your post. I couldn't find a solution so I went over every nook and cranny of my tablet and found my hard drive was not completely pushed in. I pushed it in tried the power button again and it worked! I am shocked because my laptop has been down for a year now. I thought maybe it was a motherboard problem and it was junk. I'm so excited. Anyway all I can suggest is check that the hard drive on the right side is completely plugged/pushed in. I hope that works for you.
Feb 06, 2010 | Gateway M275 Tablet PC
Touch screen (which is EVERYTING) on m NOKIA 810 no longer works. Screen is visable but NOTHING responds to touch. Any options besides using it as a paperweight?
have you tried the soft reset yet?
take out the battery and let stand in freezer (put in plastic bag to keep out moisture) for 10 mins.
hold down the switch key wich is right above the escape key on the left side of the screen. and hold down the power button till she turns on. once you get the usb symbol in the upper right turn it back off and it should run like normal.
Feb 04, 2010 | Nokia N810 Tablet PC
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Toshiba Excite 10 Tablet Logo
50 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
