Question about GE Refrigerators
It came with a white tray and I don't know what it's for.
I bought a GE Profile side by side refrigerator. It came with a white tray about 13"x7" and has 6 indentations. I have no idea what it's for. I checked online and asked the appliance dealer and no one know. Do you have any idea? Thanks.
  • corina_mille May 22, 2009
    Thank you! I have been walking around carrying the tray and absolutely NO ONE has had an answer! Again, Thank you!!
  • 1,543 Answers
That would be the Chill / Thaw try. (it allows air to circulate under the pan, so you get the fastest chilling, of say 6 cans, or thawing of frozen items safely in your CustomCool pan) It is for use in the ExpressThaw or ExpressChill mode.
The CustomCool uses a system of air dampers, a fan, a temperature thermistor and a heater. The pan is tightly sealed to prevent temperature fluctuations in the rest of the refrigerator. The controls for this pan are located at the top of the refrigerator with the temperature controls, or on the dispenser with the temperature controls (depending on model).
Empty the pan. Place the Chill / Thaw tray in the pan. Place the items on the tray and close the pan completely. On LCD display models: access by: Home>Options>Refrigerator Options>CustomCool Pan. On non-LCD models: Select the ExpressThaw, ExpressChill, or SelectTemp pad. The display and Set light will come on. Tap the pad until the light appears next to the desired setting.
Posted on May 21, 2009
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
Water is running into ice tray and does not shut off.
turn off the water at the supply and replace the watervalve
Mar 20, 2011 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile PSS26SGRB SS small water seep
under the trim there are 2 openings on on each side insert a flat head screw driver and twist so it will unlock and then it will be off hopefully you dont have to remove all insternal parts inside dispencer i will try one tomorrow at work and let you know
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PROFILE SIDE BY SIDE water line tube
Sounds like you are talking about the plastic nut that screw onto the water valve. That nut should just pull off. May have to pull kind of hard then just push onto the new line. Is this what you are talking about? Let me know.
Oct 10, 2007 | Maytag MZD2766GES Side by Side...
GE profile side by side refrigerator
In this Video Im Replacing Evaporator Fan Motor.
Sep 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
240 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
