Question about Dometic Refrigerators
New Dimensions NDRI292 Check Light stays on
Frig & Freezer performing well, but Check light stays on all the time. Why & how to fix?
SOURCE: dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Posted on Nov 11, 2008
  • 1169 Answers
SOURCE: my kenmore frig is not staying cold in frig. or freezer
Also check the defrost element in the freezer side mounted on the evaporator coil. They tend to burn out over time causing the coil to freeze up causing the same problem.
Posted on Apr 20, 2009
  • 35 Answers
SOURCE: Frig does not go below 52 degrees.. Freezer OK
MAY HAVE PUNCHED HOLE IN EVAPORATOR AND GAS LOW????
Posted on Jun 18, 2009
EllaWatson25
  • 725 Answers
SOURCE: kenmore coldspot - freezer stays cold, but frig isn't
If this model is a frost free, you probably have a bad defrost system. That would make the unit freeze up and cold air can not get through to cool the unit properly.
We have parts and supplies, so please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We look forward to working with you.
Posted on Nov 06, 2009
aasc
  • 1606 Answers
SOURCE: GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Posted on Nov 18, 2009
How do I fix ice build up at the back of the fridge compartment?
make sure door is closing properly,and turn temp down,or should I say up,warmer
Feb 17, 2015 | Refrigerators
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Sub zero model 700tc problem. frig heated up to 86 degrees. freezer is fine. What do I do?
Hello.
Well moondoggie, it sounds like your light is staying on. You can depress the light switch while the door is open to confirm this. If it doesn't go out, you need a new switch.
Give it a try and let me know.
fil
Mar 06, 2011 | Sub-Zero 700TC Bottom Freezer Refrigerator
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Refrigerator will not cool It stays at 50 degrees Freezer works fine
Look for a blocked duct or a bad fan motor in the freezer. The cooling is done in the freezer and the cold air is circulated via ducts and a fan. No air flow= No cooling in frig. Long shot could be a light not going off when door is closed, seen that a few times in 20 years...
Eric
Nov 08, 2009 | Refrigerators
My kenmore frig is not staying cold in frig. or freezer
One of the most common problems with refrigerators and freezers is over time dust and lint can accumulate in the condenser coils try cleaning the coils CAREFULLY! with a vacuum. Unplug the unit before doing any cleaning . most units have a cardboard cover in the back, remove this to get at the coils . also check the fan(if there is one ) to see that it is not stuck.replace cover and plug unit back in.
check to see if fan is running and for air movement under the front door of unit. Keep in mind all models are different and these solutions are generic ones .Hope this helps.
Bobalix
Apr 18, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Frig does not stay cold enough
you are either low on coolant or the fan inside the freezer compartment is stuck or defective.
Mar 25, 2009 | Kenmore 55203 Side by Side Refrigerator
Dometic rv refrigerator
Oct 22, 2008 | Dometic RM2652 Refrigerator
INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
My Kenmore Trio refrigerator (#596.76502500) is not working. The temp is 76degrees. The freezer seems to be working fine. I have switched it off at the circuit breaker and restarted it after 10 min. The...
The fan that blows cold air from the freezer to cool the refrigerator is not working. If your a little handy with tools its an easy fix. Its located in the freezer. Open your freezer door take off the steel panel at the back of the inside of the freezer. After you remove the panel you will see the fan the blows the cold air up to the Frig. A quick trip to a local appliance store for a new fan with do the trick. Put in the new fan 100% fixed even better than new because the orginal part is defective Kenmore should have recalled them. I have the same frig and its been perfect since I repaced my failed fan.
Aug 04, 2008 | Kenmore Refrigerators
Refrigerators Logo
10 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
