Question about Brookstone SoundShield® 501 Headphones
Headphone covers how do you get them back on
Can not get ear pad covers back on
  • Brookstone Master
  • 5,193 Answers
Some headphone cushions are caught under the plate. If this is the case (and I'm not saying it is) then removal of the plate is required. Under the black foam you might find screws. You might have to peal the foam off (you can glue it back with white Bostick glue afterwards). Unscrew them and you should be able to wrap the cushion round it.
However sometimes the cushion is not fitted like that and in which case all you can do is struggle with it. It sometimes helps to turn back the lip of the cushion all the way around. So you can slide it back into place on all fronts.
Posted on Jan 03, 2014
EAR CUSHION
Sony parts suppliers sell replacement ear pads. Part no 2-320-280-01 about US$16 each (not pair).
Old ear pads slip off - pull gently to stretch the part that sits in the groove of the headphones until one side slides out.
The creative sewer can remanufacture new pads from thin soft leather by following the pattern of the old ones.
No cost fix is to scrape off the remaining peeling urethane leaving the soft fabric backing. Headphones will still work but the soft earpads should absorb high frequencies.
Sep 12, 2012 | Sony MDRXD400 Professional Headphones
The thin black material covering the foam ear pads is flaking off and getting on face, ears and clothing. Can we get replacement pads? Dennis Christian
Yes there's a firm that might have them, you'll find it at the bottom of my tip on headphones. Just click my user name to find it.
Feb 21, 2011 | Labtec 835 Headphones
How do you open earpiece for troubleshooting no sound from right side and something rattling around
What you do is peel back the cusion of the ear pad. You might need to tear off the foam covering. You can glue it back on when your done with Bostick white glue. With the coverings gone you should see access screws.
Jan 30, 2011 | Samson CH700 Professional Headphones
I'm looking where to buy sony mdr-rf970r ear pads
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=MDRRF970RK&sessionId=FLk3TTjKj9RC2AYaSnUQb_k
This is the link from sony style for accessories and online ordering for your headset. Hope this helps.
Oct 03, 2010 | Sony MDR-RF970RK Headphones
I've noticed that replacement inner foam(that covers the speakers) and earpads are available for my Sennheiser HD 570 Headphones; how do i get the old ones off? Thanks
The ear padding is attached to and held in place by a plastic ring that fits into the speaker mount. Gently pull the ear padding outward so you can see the ring, then slip a flathead screwdriver or other object in (just a bit, you don't want to poke the speaker inside). Gently pry up , sliding your pry-bar along, and the pad should pop out quite easily.
Sep 19, 2010 | Sennheiser HD 570 Consumer Headphones
Fabric ear covers failing on my Koss headphones.
Try their limited lifetime warranty for resolution:
http://koss.com/koss/kossweb.nsf/warrrepair5?openform
Apr 21, 2010 | Koss UR-30 Professional Headphones
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
How do i change the batteries on my ha-w500rf jvc headphones
Remove the ear pad on the Left ear which has the power switch on,
The remove the 4 screws, then there are two silver screws holding the outer cover in place, remove these and then tae the cover off.
You will see there are two AA Ni-Cd batteries inside these can be replaced ith any rechargable batteries you wish
Sep 09, 2009 | Audio Players & Recorders
How do you disassembly right side headset to fix faulty connection
The headphone unit is sealed and cannot be accessed via the padded ear pads. You have to prise open the outer headphone cover which breaks off 4 internal attachment points (which can be re glued for re assembly). Be careful on the Left hearphone as it contains a complex electronic circuit board.
Aug 01, 2009 | Jabra C820s Headphones
Brookstone SoundShield® 501 Headphones Logo
89 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
