Question about Pioneer Computers & Internet
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
I have Pioneer PDR 609 CD recorder. I bought Verbatim blank discs. When I put one in and push record I get a "Pro Disc Din Unlock" message. I used another type and got "Coaxial Din Unlock" What do I do?
  • 33 Answers
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Posted on Jan 17, 2014
  • 158 Answers
SOURCE: Above burner not detecting blank CD-R disk
have you tried cleaning cd lense and if you are using nero burning rom earlier version update to latest and try any other brand of cd-r's to see if it is the make-up of the disks as some manufactors use different ways to make cd's coating and asus have on their website all media covered by the cd burners in the last resort change to a burner that is compatable with the media you wish to use the burners have come down in price so I would sugest geting a dvd burner combo doing cd's and dvd's
Posted on Aug 13, 2007
Drummernick
  • 440 Answers
SOURCE: Optiarc DVD RW AD-5170A ATA not writing DVDs
how big is your movie les sthen 4.5 gb ha sto be and u only burn at 8x never full 16x ok thx for using fix ya nick
Posted on Feb 03, 2008
SOURCE: My RCA 8310 DVD+R/+RW -VCR Combo will not format and record on a +R disc
I purchased this RCA 8310 about 2 years ago. I have recoreded hundreds of dvd's. If I try to use anything but a Imation brand DVD+R, 8+ speed, I get the same error. It will not work with a 16+ dvd.
Posted on Feb 08, 2008
  • 1019 Answers
SOURCE: Won't burn CD-r or DVD-R
make sure that your program that is setup to record. i.e nero-img burn et,c. is set to look at the drive D:- Or E:- whichever letter your drive is assigned by the computer.
Also try using a different Blank-media. if any disk has failed a full write, without finalizing Or creating the Table Of Contents. It will read as Empty Or Blank. you can see This By looking carefully at the underside of the Disk, to see whether it has been burned by the laset. ( Towards The Centre ) if the Dye is darker on the inner-edge, then this is possible.
You can also try using a different Packet writing software, or re-install the program.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 22, 2008
  • 91 Answers
SOURCE: hp 300 n
I know your problem however it is easily fixed, the burner has worn out, the laser basically is not putting out enough light for it to work properly, the best and easiest fix, goto tigerdirect.com and replace the burner, they now start as low as 24.00 and go up to around 65.00 so it's not an expensive fix.
Posted on Dec 30, 2008
Disc does not spin
First do a lens celeanup, just in case.If it does not work It may be the motor. But before opening it I suggest to check if it is under guarantee.
Feb 24, 2008 | Pioneer PD-R555RW CD Recorder
Tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 | Apple iPod touch
Need to unlock din lock
By 'Unlock din', do you mean unlock the region the recorder uses, unlock the din input or unlock the tray or what?
When recording and you see 'unlocked', it means the DIGITAL signal you are trying to record is unclear or missing.
If you are trying to record a signal from another region disc, it will not copy. Add a little detail.
Feb 21, 2012 | Pioneer PD-R609 CD Recorder
I have PIONEER PDR 609 C.D RECORDER AND I HAVE
Not a very specific problem description...
Did it ever work for you? You don't say what DOES happen when you try.
Is the signal reaching the recorder? Is it visible on the display when you select MONITOR?
Are you using CD-R AUDIO or MUSIC blank media? It requires them, not CD-R data disks.
Tape Input should be straightforward if you don't want to route it through a receiver - L and R Out from the deck to L and R Input on the CDR.
Through a receiver: if it has capacity for two decks, connect the PDR-609 itself as a the second cassette deck, then select copy, duplicate or whatever passes for it on the receiver to copy cassettes.
Without specifics of your interconnected gear I can't really go much further.
Phono is a whole 'nuther thing. Traditional turntables require a phono preamp (generally present in old receivers) to boost the tiny signal generated by the stylus to a usable level for downstream electronics. Most modern AV receivers DO NOT have a phono preamp.
Jan 31, 2010 | Audio Players & Recorders
Hi can i record on my pioneer pdr 609 cd without using the remote control,as ive purchased a unit with out one and cant get it to record, thanks
Hi John
You should be able to record without the remote control; make sure you have a blank disc in place, then press the 'RECORD' button on the front; it should go into recording standby mode. When you want to start recording, press the button below the REC BALANCE buttons (the play/pause button, marked with a triangle and a II symbol) and this should get you going.
Try it and get back to me if not.
Hope it works!
Kev
Jul 25, 2009 | Pioneer PD-R609 CD Recorder
Can't get it to record
I experienced this problem a long time ago, i believe that it was because i tried to use a normal data cd-rw but the unit only reads audio discs. It has to be a cd-rw for audio only (will say cd-rw audio on the disc, whereas if it is a data disc it will simply say cd-rw.) Hope this helps..
Mar 13, 2009 | Pioneer PD-R509 CD Recorder
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
I can not get my CD recorder to record
You should use consumer cd's that are rather expensive. You probably tried to record a recordable cd-rom (a cheap computer disc). It's not possible to burn a pro-disc (computer disc) by using your Pioneer, and that's why you got that message on the screen. Refer to the user manual of your cd recorder and learn what sort of blank cd you should use.
Aug 05, 2007 | Pioneer PD-R555RW CD Recorder
Computers & Internet Logo
103 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
