Question about Admiral Dryer. 6.5 cu. ft. Electric Dryer in White AED4675YQ
Dryer won't stay running without holding down the start button
The only way the dryer will stay running is by holding down the start button, tried unplugging the machine, waiting 5 minutes, along with emptying the dryer, cleaning the lint trap. Nothing still won't keep running
  • 451 Answers
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Posted on Jan 02, 2014
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Sep 29, 2012
I have a kenmore elite King size Quiet Pak II dryer that won't stay on unless i hold the button down and even when i do that the dryer is not getting hot.. Any suggestions would be...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Dryers
Kenmore 90 series dryer, the button to turn it on won't stay depressed unless you stand there and hold it down. is there a part i can get for it to fix it or should i just get a new dryer?
heatman101
Aug 11, 2011 | Dryers
My kenmore dryer will only run if i hold down on the start button. this has happened to me before but i cannot remember the steps to take inorder for it to reset.
first check the door safety switch,, if its bad the dryer won't run,, if that checks out ok, its time for a new switch for the start button, to check these, and do the door switch first, unplug the door safety switch and place a jumper wire between the 2 wires leading to the switch, try starting the machine making sure your away from any moving parts , if this works, replace the switch, if it stays the same, do this same procedure to the switch for the start button
Jun 21, 2011 | Kenmore Dryers
Dryer won't stay running after pushing the button.
that isn't the model number,it will start with 110. or 417.send the full model number and i can look up your dryer,most likely it's the even heat board or the motor relay but without the model number i can't look it up for you,these parts are in the top console,call the parts store give them the model number and they'll give you the right part or send it to me,let me know what you find
Jul 20, 2010 | Kenmore 63942 Dryer
Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
Dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
May 24, 2009 | Dryers
Dryer wont keep spinning without me holding the start button down
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Kenmore 64902 Electric Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Amana Dryer will not work,will not stay on,makes funny noises
during the process of moving your dryer, it sounds like the drum became dislodged. With the dryer off, open the door and try to move the drum by hand, if it sounds like something is 'dragging' them the drum is off its bearings. IF it is, the quickest way to get help to take it apart is go online to youtub, type in your dryers name and model number and ask how to replace drum
Apr 27, 2017 | Maytag MDE2706 Electric Dryer
Admiral Dryer. 6.5 cu. ft. Electric Dryer in White AED4675YQ Logo
242 people viewed this question
Top Admiral Dryers Experts
Timllfixit
Are you an Admiral Dryer Expert? Answer questions, earn points and help others
