Question about Dacor Microwave Ovens
How to clean microwave touch panel - Dacor Microwave Ovens
Ge microwave m# pvm2070sm1ss. Control panel nonresponsive, attempting to check if creen lock is engaged but cant get past "change the filter"message.
I have never seen a home microwave that shuts down the unit to have you clean the air filter. Mostly they are reminders that stay up for a preprogrammed time. Have you tried to unplug the unit,let it set for a couple of minutes, Plug back in, set the time of day (clock ) and try it again?? If you get NO action from the touch panel, the touch panel may be bad.
Aug 24, 2017 | GE Microwave Ovens
Help! GE spacemaker 2.0
I had the same problem , it was finger touch control panel, when I cleaned with spray then it worked for some days . Finally to get ride of it , I changed control panel with a new one.
May 12, 2013 | Microwave Ovens
My touch panel on the door does not work. any
When these go out the usually have to be replaced, there are no replaceable parts for them. Usually you have a stuck button and this is from pushing it too hard, or cleaning fluid gets into the pad and the problem is the whole touch pad gets ruined and has to be replaced. Unless your familair with small appliance repair I would have a tech look at this.
Mar 23, 2011 | Electrolux EI30BM55H Microwave Oven
GE Profile Microwave Oven with an F1 error code
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 11, 2010 | GE Profile Spacemaker Over-the-Range...
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Benjamin
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
Kenmore oven-microwave 911 41479791 I get E 01 error.
Feb 18, 2010 | Kenmore 63662 / 63664 / 63669 Microwave...
On button no longer works
Without your brand and model number, it's hard to give specific guidance, but when a microwave won't start, the first suspect is a bad door switch or door switch mount. See this file.
You mentioned that you clean the touch panel. I hope that a cleaning spray was not sprayed directly on the controls or on the oven. That's a big killer of controls.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Contract us if you need more free advice.
Jan 31, 2010 | Sharp R-120D Microwave Oven
My microwave Oven, send a F1 messagge and doesn´t work. What can I do?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Dec 17, 2009 | GE JE1390 Microwave Oven
While cleaning it the vent began to open and close and the microwave would not shut the vent down when the keypad was used to end the cycle. Now it only shows F3 on its screen when we try to set it up...
The "F3" error code means "Shorted key panel (touch pad)". The correction is to replace the key panel aka a membrane switch or a touch pad. The control panel in that case is just a plastic frame.
please rate this help to keep us online
Aug 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Touch screen not responsive. Can operate oven only by pressing one-minute button. Cannot set clock, change settings, etc.
try opening up the control panel,disconnect the connector ribbon coming from control panel and connected 2 control board by just pulling it out and cleaning end of connector ribbon and iserting it back.some times this works.if not then 4 sure touch panel needs to be replaced.
Aug 15, 2009 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
