PITNEY BOWES 3C00/4C00 POSTAGE MACHINE USER GUIDE
MitchSchaft
  • 25 Answers
SOURCE: pitney bowes 1530 / INCOMING fax date/time stamp
For the UF-595 here's how you turn the fax stamp on:
Function + 7 + copy/set for enter
scroll to option 4 + copy/set
Hit 04 + copy/set and enter number 2 to turn the fax stamp on. 1 turns it off.
Scroll to or enter 28 and choose 2 to turn the fax stamp on for faxes stored in memory for later use.
You hit the "clear" button to wipe out the current number before you enter 2 or 1 for the new entry.
Posted on Jan 25, 2008
leroyal
  • 2120 Answers
SOURCE: Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
Posted on Jan 31, 2009
  • 18 Answers
SOURCE: New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
Posted on Aug 24, 2009
  • 159 Answers
SOURCE: I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Posted on Dec 22, 2009
Testimonial: "I followed your tip which produced a contact# that led to the needed answer."
  • 149 Answers
SOURCE: pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Posted on Dec 24, 2009
I Can not see the screen on my pitney bowes dm100i?
Screen contrast probably needs to be reset which can be done by:
1. Unplug the power cord
2. Press the #4 AND KEEP HOLDING IT DOWN UNTIL METER IS FULLY started aafternext step.
3. Keep the 4 button pressed & plug the power cord in, while keeping the 4 button held down.
After meter fully boots the screen will be restored to normal if contrast settings were the problem.
If this doesn't resolve the problem, the screen or control panel is bad & should be replaced. This should be covered under yourpPitney Bowes warranty while meter is onlease.
Apr 29, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Postage meter is saying a connection cannot be made to call support
This frequently happens when the location uses digital telephone lines. The meter is more specific than fax machines and does not work reliably on any phonelline that is not true analog like an old home phone line before vonage & cable phone service.
Alternatively you can connect thru the Internetusing a usb cable and pc/laptop with Pitney Bowes pc meter connect software which is free on Pitney Boweswwebsite or the larger model meters can connect directly to a corporate networkwwithouta pc aas middleman.
Apr 01, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Where can I get a postage meter?
In the US there are five authorized vendors for postage meters in the US. They are Pitney Bowes, Neopost, FP Mailing solutions, Data-Pac Mailing Systems and Hasler Inc. Make sure you get it from an authorized vendor because you want to make sure you're getting it legally.
Sep 16, 2013 | Office Equipment & Supplies
Pitney Bowes E700 doesn't print at all althougth the mechanism appears to be working fine. I've changed the cartridge and cleaned the print head and run maintenance several times but to no av
Addressing Original Question: Its essential that the PB E700 machine is linked to Pitney Bowes account to either a) add postage or, b) carry out an Inspection. within 90 days or machine will start flashing "Inspection Due" if this is ignored after a further 30 days the machine will start flashing "Inspection Required" and stop printing! Perhaps this is the solution required.
a) First Connect machine to telephone line as if you were going to top up with postage.
b) Press "Refill"
c) Press "0"
d) Press "Enter"
Machine should display your current balance with PB.
And the Inspection message will be cleared.
Hope that helps. I also misunderstood the "Inspection" message thinking it was referring to a maintenance requirement, when it is actually an antifraud/security requirement of the postal authorities to check location and usage of the machine.
Mar 07, 2012 | Office Equipment & Supplies
Dec 21, 2009 | Office Equipment & Supplies
Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Aug 20, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
Pitney Bowes Fax Function Question
I have a 9920 manual,could be the same.Try the following but if you get different displays don't change anything.Press function,should read FUNCTION SELECT , ENTER FUNCTION # .Enter 8, scroll to AUTO REDUCTION.(use COM STAT or HELP keys to scroll)Change to NO.Press stop to return to normal mode.If this procedure is not exactly the same for your model,then just search through the function settings and find AUTO REDUCTION and set to no.
Mar 05, 2008 | Office Equipment & Supplies
Televison & Video Logo
296 people viewed this question
Top Televison & Video Experts
