Question about Hamilton Beach HB-P90D23 Microwave Turntable Plate Glass Cooking Tray 10-5/8"
Door stuck closed
The door will not open. (To complicate matters, there is a cup of coffee inside.)
  • keri Jan 04, 2014
    I called Hamilton Beach and was assisted by a very helpful tech person ... but, alas, nothing we tried got it to open. Finally, he suggested that we could 'jimmy' the door and (at the least) retrieve my coffee cup. The bottom of the door moved about 1/8" and the top not at all, so we stuck a slender pry bar behind the edge of the door and worked it open, sticking a thick screwdriver in the opening as we worked our way down toward the bottom. Finally, with a mighty push, it popped open. Since the oven itself still works he suggested trying a small appliance repair shop to see about fixing the latch. But, given the price of small MWs these days, we opted to toss it out and buy a new one. Pity! All for the sake of a faulty latch.
I have a Jenn air micro wave and I attempted to heat up a cup of coffee in a plastic cup and forgot about it when I smelled something burning I discovered that the cup had melted and the microwave had
Take a lemon and slice it. Put it in a ceramic bowl of water. Set the timer for 10 minutes. Leave for an hour and then wipe the inside with a clean cloth. It will get ride of the smell, if that was your question? It the cup has stuck to the turntable, set microwave for 1 minutes and scrape the cup off with a paint scraper.
Dec 02, 2016 | In Microwave Ovens
Why did the glass in microwave door shatter melt?
A spoon in the coffee the cup had metal parts
Feb 20, 2015 | Frigidaire Microwave Ovens
Why microwave won't stop running unless door is open ?
Is it actually heating or just making noise and acting like it's heating? (put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is 1 of the door switches is not working right (it's either stuck open or stuck closed).
Aug 16, 2014 | Whirlpool Microwave Ovens
Microwave turns on when the door is open must un-plug to shut off
Is it actually heating or just making noise and acting like it's heating? (Put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is that one of the door switches is not working right (it's either stuck open or stuck closed).
Aug 15, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
My microwave is cooking without me wanting it to
The fact that pressing CANCEL did nothing leads me to believe the controller may have failed but a failed door interlock could be a contributing factor.
Jan 08, 2014 | Kenmore Microwave Ovens
Door won't engage and stay closed
Possible that the lock was broken and so the door opened. You can remove the front panel and check for broken plastic or nylon pieces which can be glued using instant adhesive.
Reset the lock and switch and the door must lock in correctly
Jan 21, 2013 | Microwave Ovens
Grinder appears to be grinding, but not ground coffee ends up in the basket. Metal door underneath the grinder is closed.
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
Sep 06, 2011 | Microwave Ovens
Microwave will not stop running when door is opened
The door switch need to be changed. It is probably stucked close. These switches are available at most electronic parts supply.
Jun 30, 2009 | Panasonic Microwave Ovens
Microwave runs with door open
there is a safety switch located on the door frame chances are it need replacing since it is staying activated
Dec 12, 2008 | GE JVM1650 1000 Watts Microwave Oven
Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 27, 2007 | Maytag MMV1153A Microwave Oven
Hamilton Beach HB-P90D23 Microwave Turntable Plate Glass Cooking Tray 10-5/8" Logo
91 people viewed this question
Top Hamilton Beach Microwave Ovens Experts
Andrew Taylor
Andrew Taylor
Are you a Hamilton Beach Microwave Oven Expert? Answer questions, earn points and help others
