Question about Hotpoint WMA58 Front Load Washer
Water is not heating
Washer is working but water has stopped heating
  • 108 Answers
Hi u can put multmeter across heater you should get reading around 27on meter or close its been a while since ive done one
Posted on Feb 17, 2014
The dishwasher doesn't finish the 30 min program. The display shows 1 minute remaining but the washer doesn't stop.
It sounds like the d/w has a heating issues. Possible internal failure of the heating relay.
Jun 20, 2016 | Dishwashers
My Roper washer will run through wash cycle then stops. Nothing will work for 40 minutes then I can put it on rinse then the cycle will complete. What could cause the stopping with nothing working then...
It could be that the machine is trying to heat the water in the drum, but is not able to for some reason. The timer is waiting for the water to reach temperature before advancing. Posssibly a broken heating element. This can happen even on a cold cycle as most machines prefer to heat all soaping water to about 30C regardless of the temperature setting.
Sep 13, 2013 | Roper Washing Machines
Washer stops in middle of cycle and flashes error code f 05
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor.
Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
Nov 01, 2012 | Whirlpool Washing Machines
I have a Whirlpool washer. It will fill and run through the first cycle and then stop... What would cause this?
I would pretty much guess it's a faulty heating element. After the machine stops after filling with water and running a while to get the clothes wetit stops to heat the water. Listen carefully to hear the water heating up, it sound simular to an electric kettle. If this does not happen the program is unable to advance.
Apr 06, 2011 | Whirlpool Washing Machines
Stop work and is showing a code f 05
Water temperature sensor error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Dec 14, 2010 | Kenmore HE2 Plus Front Load Washer
In the middle of a load my washer will stop and starts flashing F23? It is a whirlpool duet steam.
Hi, F23 means that there is a fault in the heating circuit and the heater is not working This fault is triggered if the water fails to rise by 30C or 86F in the first 8 minutes of the heating process.
2. Check the connections to water heater.
3. Check resistance and continuity of the heating element.
4. Check the water temperature sensor and connections to it.
5. Check the water temperature sensor and connection to it.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
Potential Causes
Replace failed component.(Most common issue will be a failed water temp sensor)
Jul 25, 2009 | GE WBVH6240F Front Load Washer
Stops at rinse cycle
need more info, has the machine heated up the water during the main wash? is there a blockage in the filter?
Apr 05, 2009 | Washing Machines
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool awg 338 washer
initially check the element for continuity then check that any part of the wiring has not come off. if the water does not heat up it may not be advancing the timer to continue with the later stages of the wash, ie waiting for the stats to say the water is warm enough. tone.
Jun 04, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Hotpoint WMA58 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
