Question about iRiver Audio Players & Recorders
Aj251_v3 071016 MP5 Need Firmware aj251_v3 please share.. board id: aj251_v3 071016 sunplus: spmp3052a
  • jackel_lero2 May 24, 2009
    i'm still waiting for the firmware...huhuhu
    hope this help me...thanks dvdcdlaser muahh....
    President:
  • 1,285 Answers
Posted on May 23, 2009
Psp mp5 firmware
Oh my god...I have the same problem...
May 05, 2013 | Chinaewindow PSP MP5 Player
HI Good day.. my dearest friend had a SUNPLUS mp4.. It's Specs are: CHIP: Sunplus 3052A CAMERA: ST30 and here is the problem... ***BOARD ID*** This unit has two Board ID printed on it... One at...
It;s probably best to buy another as the right firmware is always notoriously hard to find on those Chinese players.
Get yourself a Sansa Clip+ instead.
Mar 02, 2017 | Sunplus Digital Still Camera Device
I own a vivicam 3718 s and i lost the Cd for it to put on my computer to upload the pictures wonder if you had a web address for me to get it from thank you
I have only this info about this Camera, hope help you
This Sunplus SPC533 driver only support Windows 98, ME, 2000. Please refer to this page:
http://cr.am/framed.php?url=http%3A%2F%2Fwww.softwaredriverdownload.com%2Fsunplus_spca533_driver.html&ref=driverguide
Please note that SunPlus doesn't build cameras, they make chipsets for camera makers to use in building their cameras.
This is the driver for Sunplus SPCA533 digital camera. Sunplus website does not have the file available for download. Thus this driver file is download from third party website.
Mar 13, 2011 | Cameras
Sir, I Have JXD 656 recently I connected it to my
WARNING : This procedure can render your device dead, so do not try if your player is working fine.
  1. The most important step of the whole process is to correctly identify your device CONTROL CHIP and CPU, using wrong firmware or flashing tool may cause damage to your device, unscrew and open your device and write down all chip id's and motherboard numbers you see, you can also try the EasyChips - firmware identification utility but it did not worked for me.
  • You will now need to download the correct firmware and flashing utility for your device, visit sites below and search for your control chip and cpu to download the firmware and flashing utility, you can also post on user-forums to get help identifying the firmware :
  • In my case the chipset was Sunplus AJ262-V7 and the utility needed to flash it was FRM Pro.
  • Once identified you need to connect your device to computer via USB in camera mode (Press A + OK button and plugin USB cord on player), for Windows to identify this mode you will need camera drivers you need to point Windows Found New Hardware Wizard to Driver folder downloaded with the FRM Pro utility above, this will install the first camera driver, for correct identification by flashing utility you need to install a second camera driver - open Windows Hardware Manager and install unidentified camera device drivers by pointing the driver wizard to Driver folder used earlier.
  • Now install and launch FSM Pro flashing utility the new firmware.
  • Jan 13, 2011 | Audio Players & Recorders
    I erased some things i didn't think i would need from the mp3 player (photo folder, etc.) and now when it turns on it just says "Load main image failed, switch to recovery mode"
    STEP 1: Soft Reset
    Simply press and hold the power button for 20 seconds. The soft reset would refresh the player. After doing the soft reset, try to turn on the player once more. If this didn't resolve your issue continue to step 2.
    STEP 2: Firmware Update
    Firmware controls the functions of your device (how your device operates). In cases where the product does not perform as intended, the update fixes the issue by replacing the current firmware with the latest enhanced version.
    Please be reminded that for your player to work properly you need to meet the requirements below.
    - Windows XP SP2 or higher
    - Windows Media Player 10 or 11
    To Download the Sansa Firmware Updater, you may copy and paste this link to the address bar of your web browser:
    http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
    To Know More on Using the Sansa Firmware Updater:
    http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=306
    If you encounter any issues with the Sansa Firmware Updater, we can try to use the Manual Firmware Update.
    There are three versions of the Sansa e200 - Version 1, Version 2, and Rhapsody. This can be found by going over to "Settings" if you found "format" then you have a "v2" or look at the back of your player and check the exact model number under the "CE" logo it should say "model:e200" for Version 1; "model:e200 V2" for Version 2; and "model:e200R" for Rhapsody Version. Make sure that you choose the correct firmware version for your device as updating it using the wrong firmware version may render your device useless.
    E200 Manual Firmware and Instructions:
    http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=15209
    E200V2 Manual Firmware and Instructions:
    http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=13548
    E200R Manual Firmware and Instructions:
    http://forums.sandisk.com/sansa/board/message?board.id=e200R&thread.id=2280
    Dec 25, 2010 | SanDisk Sansa e200 MP3 Player
    If I turn on my mp5 no programs appear..it only lights on and has no even folders to open!!it seems that my program was corrupted!
    yes,your firmware is corrupt you will installing the firmware here the link how to fix: www.dhakamobile.com/...mp4.../11002-procedure-how-fix-mp5-loading-problem-frm-software.html
    Dec 18, 2009 | Panasonic SV-MP510 MP3 Player
    How can i download games for my mp5??
    If your MP5 supports '.nes' games like mine does, then try downlading .nes ROMs...
    .nes are originally Nintendo Entertainment System files
    Jun 01, 2009 | Nintendo Donkey Kong Country 2: Diddy's...
    Lost firmware of IMP-65 MP3 player
    her is a link for the firmware download
    IMP-65 Firmware
    If this helps please rate the post.
    Mar 02, 2009 | Audio Players & Recorders
    Hii! I Need Help!
    This model does not support MP5 formats.
    If the package says "MP5", it's because it's wrong.
    If not, please update the firmware or find a customer service representative for repairing.
    Aug 03, 2008 | Creative Labs ZEN V Plus MP3 Player
    Firmware problem
    i have a muvo2 fm and reloaded the firmware off the creative website..
    Jan 24, 2007 | Creative Labs Nomad MuVo2 FM MP3 Player
    314 people viewed this question
    Top iRiver Audio Players & Recorders Experts
    Steven Wander
    Steven Wander
    Mohamed Ismail
    Mohamed Ismail
    Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
