Bush a147cr6b model showing e01 i have changed interlock have checked wiring all ok what else could cause thisplease
2 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: Hi, my bush a147CR6B washing machine isn't functioning, it's flashing CL (childlock) does anybody know how to turn this off?
Press the EASY IRONING and the DELAY TIMER together for 5 seconds to turn the child lock on or off (It's in page 12 of your manual)
Posted on Aug 26, 2016
Aug 26, 2016 | Washing Machines
AEG Lavamat washing machine model 76850, shows a blinking key and makes clicks and after that shows E40. Thanks John
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensing circuit faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Aug 02, 2014 | AEG Washing Machines
How can i replace the drum lifters in my Bush A147CR6B washing machine?
They are hard to replace. Be careful and wear a pair of goggles. You must be strong and careful when doing this. A pair of mechanical pliers and a long slender strong flat edge screwdriver will do the trick.
Jan 12, 2014 | Hotpoint Ultima WF860 Front Load Washer
Bush dishwasher is showing e3 whats the problem
All codes E01, E02, E03, E04 and E05 all indicate a power module failure. Please test the following with the VOM. Sounds like a door switch problem here. Make sure you door closes and latches properly. If it does, you must gain access to your door switches and check for proper continuity and OPS of switches. Can also be a keypad or control issue, but make sure your switches are good first.
Of course you must test the output outlet from wall, reset the c. breaker see the diagram attached, observe the polarity very IMPORTANT. God bless youe73d4c1c-79f0-4b2c-a829-50eabcfad2be.jpg
Apr 05, 2013 | Bush Dishwashers
Hotpoint ultima extra washing machine, door open sign flashing on lacd display even though the door is closed properly
first check all connections on circuit board are tight if ok change interlock,if problem still persists you have a circuit board fault which could have been caused by blown interlock
Sep 08, 2011 | Hotpoint Washing Machines
My hotpoint wm52 won't start ,its completely dead no lights ,have checked sockets,plugsand fuse all ok ,have also changed interlocking system still nothing
main timer is blown along the door lock tracks. you can repair it with a soldering iron and a small length of wire. It blew because the interlock went faulty
Mar 28, 2010 | Washing Machines
The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Aug 19, 2009 | Televison & Video
Washing Machines Logo
Top Washing Machines Experts
