Question about Canon FAX-L400 All-In-One Laser Printer
Paper jam /Message says Rec. Paper jam Open right cover
Paper jam in canon fax 400
  • 1,219 Answers
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
Posted on Apr 30, 2010
Rec. paper jam open right cover
Obviously you have a paper jam somewhere. Probably one the right side, open all the covers and pull the paper out.
Oct 20, 2013 | Canon FAX-L400 All-In-One Laser Printer
I am getting rec.paper jam no paper jammed though
Open back door, clean feed roller very well, and open and close upper cover.
May 28, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Paper jam
Open the paper tray and remove the first couple of sheets of paper - If the paper tray is fully loaded leave it half full.
May 21, 2009 | Canon Office Equipment & Supplies
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Paper jam message, but no paper visible
Are there any traces of paper in the printer? Have you tried by restarting printer?
Mar 18, 2009 | Canon PC-D340 All-In-One Laser Printer
Rec paper jam message.
Normal 0 I suggest you get a sheet of Card Stock (Heavypaper) and place it in the feed way. Then press the printbutton applying a slight amount of pressure on the Card Stock so itwill feed through the printer. The reason for this is in some cases Ihave been able to clear the paper track of debris that was deposited thereover time.
Worth a try, as I have fixed a number of printers thisway, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon Laser Class 8500 Printer
L-50 machine gets Rec.paper jam slide platen left
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Oct 31, 2008 | Canon PC-1060 Black and White Copier
Canon 2060p message check/cover paper
there is a little white piece of plastic that gets stuck when you put in or take out toner catridges when not in the right position it cause that notification thank you again
Oct 14, 2008 | Canon LaserClass 2060 Fax
Rec paper jam
When you open the rear door you will see roller- clean it with water or alcohol and dry it.
Aug 11, 2008 | Canon CFX-L4000 Plain Paper Laser Fax
Rec . paper jam
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
Dec 13, 2007 | Canon FAX-L350 Plain Paper Laser
Canon FAX-L400 All-In-One Laser Printer Logo
684 people viewed this question
old marine
old marine
