TV Not turning on
Hi, I have recently been given a broken Phillips 42PFP5532D / 05 which won't turn on, apparently it just stopped working one day. I have working knowledge of PC repair so decided that I would try fixing a TV ago but as I have just found out, they are quite different. I believe the problem lies somewhere on the power board but I'm unable to determine exactly what is wrong the TV. When I plug the TV in you can hear the power click and a blue light appears on the front but the screen is totally black, exactly as it is when the TV is not connected to the power. Upon pressing the the power button on the side of the TV the blue light on the front goes out and no other lights come on, this is also accompanied by another click from the what I can only assume is the power board inside the TV. To try and diagnose the problem further I removed the back panel and plugged the TV into the mains power again. Same thing happened, blue light came on, nothing on the screen. I located the power board and noticed a steady green LED and some reference numbers to error codes. Upon pressing the Power button on the side of the TV again the Same click can be heard, the blue light on the front goes out and the green LED on the power board flashes 9 times and then 10 times. It continues to flash 10 times repeatedly with a small pause inbetween (just to clarify it flashes: 9, 10, 10, 10, 10 and so on). When corresponding the flashes with the error codes printed on the power PCB they are listed as the following: 9: OVP, DC_PROT 10: PROT I have visually inspected the capacitors but can't see and leakage or bulging although I may have overlooked something, I'm not sure. Any help or advice I can get to point me in the right direction would be greatfully recieved, I've got this far but am now are a loose end! Seems a shame to throw it out if it's something that I can fix. Cheers!
    Top Expert:
  • Televison & ... Master
  • 34,814 Answers
You can be pretty sure something's wrong with the power board. Defective capacitors may "look" OK but aren't. It could be helpful to lay your hands on a schematic.
Posted on Jan 02, 2014
  • Russell Penella Jan 28, 2014
    Just rebuild or replace the power supply board. Cheap on ebay or shopjimmy.
2 Suggested Answers
maatmartin7
  • 1210 Answers
SOURCE: Have a Magnavox 37mf321d LCD TV, one day, went to
Although a capacitor may look good, it may be weak or bad. Here is what you will have to do. Replace capacitor (location) 2074 which is a 25 volt 2200Mf at 105 degrees. Replace capacitor (location) 2081 which is a 35 volt 1200 Mf at 105 degrees. And you should change capacitor 2066 which is a 16 volt 10Mf at 105 degrees. Please be careful with the last cap mentioned. You can easily tear the PCB trace if you are not extremely careful. This should bring your TV back to life. Thanks for asking and show a few hands of support!
Posted on Dec 25, 2010
Hi all could someone help me please I have a philips 42pfp5532d and its stuck in digital tv and when I press menu nothing comes on the screen . What do I need to do ??
Search or call Phillips and see how to reset the TV back to the factory settings. Sometimes its as easy as hitting a couple of keys on your remote. Good Luck
May 02, 2016 | Philips Televison & Video
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Mar 11, 2012 | Philips 42PF9431D/37 TV
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
Philips 42pfp5532d 05 plasma tv won't store tv channels. when turn off then back on has to scan for tv channels again.
I had the same problem a little while after the digital change over, channels were all lost struggled to get the set up menu up but when i did i retune the channels as soon as you turn the tele off there lost again. but it works if you leave the tele on standby. 2 people have told me it's the battery in the tele itself.
Aug 26, 2011 | Televison & Video
I have a phillips plasma tv. model 42pfp5532d/05. i canot tune in the digital channels. what do i need to do ?
to get digital, you need to do the autoprogram or channel scan.. then it will find them and add them to your channel. point your antenna toward your towers and re-scan the channels. if you want digital cable, you need a cablecard (where applicable) or cablebox to decode..
Feb 18, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Phillips 28PW6006/05-Locked
First you need to get your remote working, without it you cannot unlock the tv. If the romote is not phisically broken (or smashed) make sure the battery contacts are clean and install new batteries.
Once you get the remote working (hopefully) Enter the MENU and select 'Features'. Set the Child Lock to OFF. If you cannot get the remote to work try a universal remote, setting it up with the codes for your tv provided in the setup manual for the universal remote.
Mar 17, 2008 | Televison & Video
TV "X-Ray" Error
HI Matt of south Africa Every Tv has an xray protection circuit.that circuit is faulty os you will have to take it to qualified tech to repair your tv.good luck.
Apr 26, 2007 | JVC AV-A21M3U 21" TV
Televison & Video Logo
1,687 people viewed this question
Top Televison & Video Experts
Electro Med Services...
