Question about Frigidaire Dryers
Sanyo Gas Dryer does not heat. - Frigidaire Dryers
Gas Dryer has heat at beginning of cycle then no heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 05, 2010 | Whirlpool LGR3624JQ Gas Dryer
No heat/ gas dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 04, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer not heating up
heatman101
May 24, 2010 | GE DPSE810GGWT Gas Dryer
Neptune MDG5500AW Gas Dryer: gas dryer will not heat...
heatman101
May 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas Dryer no longer putting out heat.
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
Not heating
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 12, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Not getting heat
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
heatman101
May 05, 2010 | LG DLG2532 Gas Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
No heat gas smell
heatman101
Mar 08, 2010 | Estate EGD4400SQ Gas Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
Dryers Logo
12 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
