Question about Tannoy Audio Players & Recorders
Screw in pins for rear of speaker have snapped need replacede
Pins that hold speaker cables have snapped and need replacing
  • 29 Answers
Try maplins
Posted on Jan 09, 2014
Where i bulb located on a mitsubishi wd 62525 rear progection hd tv?
Through the front of the TV. Remove the speaker grille (IT SNAPS OFF & ON) & there is a lamp cover with 3 screws holding it in place, near the left speaker.
That lamp part#: 915P020010 $49.00 TO $100.00
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-62525
Jun 03, 2014 | Philips 60PP9202 60" Rear Projection...
Nelco sewing machine 234F - stitch length knob wont turn
My Nelco Sierra 234F stitch length dial was stuck. Turns out it's pretty easy to repair if you are handy with tools.
Remove top of the machine. Remove set screw holding stitch length mechanism to body about half-way down inside. I loosened the screw and used a magnet to retrieve the screw and washer. Gently pull mechanism out the front, jiggle a bit to disengage rear cylinder from lever and pin inside body. When out remove two screws holding rear cylinder to mechanism and remove, note that the opening in the cylinder should be up when the dial is set to "button hole."
Remove the small snap ring holding the reverse button push rod and spring and pull it out. Remove snap ring holding outer cylinder onto inner cylinder...this probably requires a snap-ring removal tool.
Work the outer cylinder free from the inner cylinder by using lubricant (maybe let it sit over night), twisting with a wrench, whatever it takes. The problem is that the oil/grease between the two cylinders has dried out and become sticky.
Once the outer cylinder is off clean everything and verify the cylinders turn freely when assembled. Lightly file the cylinders smooth if you gouged them when taking them apart. Lubricate with oil or light grease, reassemble and reinstall the snap ring. Reinstall reverse button push rod, spring and small snap ring. Reinstall rear cylinder with the two screws, note orientation of opening in rear cylinder.
Installation is a bit tricky, you have to turn and wiggle the mechanism to get the pin on the lever to enter the side opening of the rear cylinder. Lifting the lever and pin mechanism from the top can help by moving the pin rearwards. It took me a few tries.
Once it's in orient the set screw hole in the outer cylinder under the set screw opening in the body and reinstall the set screw and washer (I used a magnet to lower the pair into the screw hole).
Reinstall cover and you are good to go. If you drop the set screw or washer remove the bottom and retrieve them, or fish them out with a magnet if you can see them.
Jun 01, 2012 | Sewing Machines
Canon a1100is camera battery door replacement
Kurt- I have successfully completed a d-i-y battery door replacement on my Canon A1100IS, and I make no claims about being an "expert." My training was watching u-tube videos of guys disassembling digital cameras (other models). Here's how to open the case on the A1100is, which is not really much different than opening the case on most any compact digital camera.
Using a size #0000 phillips screwdriver (Sears sells a set of 6 minis--slotted and phillips--for $10), I removed the nine screws from the side and bottom of the case plus one inside the mini-usb cover and the one inside the battery compartment.
Then, I gently worked the front and rear of the case apart (the top of the case halves have two snap clips that hold them together. Unlike some cameras, the A1100IS does not have any flexible cable straps between its front and rear covers.
With the case halves removed, I then used a tweezers to move the straight end of the hinge spring out of its original place next to the tripod socket. That released spring pressure on the hinge and I could then easily remove the hinge pin with the tweezers.
Then, it's simply a matter of placing the replacement door's hinge/spring combo in the proper location and inserting the hinge pin to hold it there. I purchased a new door from Canon for $8.42 plus shipping). Then, I used the tweezers to position the straight hinge spring end in the slot next to the tripod socket.
The only thing left was to wipe my fingerprints off of the LCD screen and then gently replace the front and rear case halves--snapping the case's top together and then replacing the nine screws.
Feb 26, 2012 | Canon PowerShot A1100IS 12.1 MP Digital...
How do you remove the inside door panel backseat right side of a mercury grand marque 1996
Door Panels REMOVAL & INSTALLATION 1989–91 Vehicles
  1. Disconnect the negative battery cable.
  2. On 1990–91 vehicles, remove the speaker grille.
  3. Remove the retaining screws from the door inside handle cup.
  4. If equipped with armrest courtesy lamps, remove the lens, detach the bulb and wiring assembly from the pull cup and remove the pull cup.
  5. Working through the pull cup opening, disconnect the remote lock rod from the lock knob.
  6. Remove the retaining screw and the remote mirror bezel nut from the power window regulator housing switch plate, if equipped.
  7. Raise the plate to expose the window switch and power door lock switch and disconnect the switches.
  8. Remove the retaining screws from the armrest finish panel.
  9. Remove the retaining screws from the armrest and remove the armrest.
  10. Using a suitable trim pad removal tool, carefully pry the trim panel plastic push pin retainers from the door inner panel. NOTE: Do not use the trim panel to pry the clips from the door inner panel. Replace any bent, damaged or missing push pins.
  11. Disconnect the radio speaker wiring, if equipped.
  12. Remove the trim panel and watershield. To install:
  13. If the door panel is to be replaced, transfer the plastic push pins to the new panel. Make sure that the watershield is positioned correctly to the door sheet metal. Remove the door pull handle from the old panel and transfer to the new one.
  14. Position the door panel loosely to the door belt opening and route the wiring harness through the appropriate access holes in the panel.
  15. Connect the radio speaker, if equipped.
  16. Align the plastic push pins on the door panel to the holes in the door sheet metal and press the pins into place.
  17. Install the armrest and route the window regulator, remote mirror cable and power lock harness through the access hole.
  18. Install the armrest finish panel.
  19. Install the power window regulator switch plate housing to the armrest connecting the power window switch, power door lock switch and remote mirror bezel nut, if equipped, prior to securing the retainer screw.
  20. Connect the lock remote rod to the lock knob retainer boss. NOTE: Make sure that the remote rod is fully seated into the retainer boss, then function manually or with the power switch to ensure smooth operation of the lock knob.
  21. Install the bulb and wiring assembly.
  22. Install the lamp lens, if equipped, and the pull cup.
  23. On 1990–91 vehicles, install the speaker grille.
  24. Connect the negative battery cable. Fig. 1: Front door panel — 1990–91 vehicles 84170064.gif
    Fig. 2: Rear door panel — 1989–91 vehicles 84170065.gif
1992–98 Vehicles
  2. If removing the driver's door panel, remove the nut from the outside rearview mirror control switch.
  3. Remove the window regulator switch housing by gently prying up, starting at the front. Fig. 3: Front door panel — 1992–98 vehicles 84170066.gif
    Fig. 4: Rear door panel — 1992–98 vehicles 84170067.gif
    Fig. 5: Remove the window regulator switch housing by gently prying up, starting at the front 89600p08.jpg
  4. Detach all connectors from the switch housing.
  5. Remove the door inside handle cup.
  6. Remove the push pin from the door trim panel upper front extension and remove the screw.
  7. Remove the lower self-tapping screw retaining the door trim panel to the door inner panel. Fig. 6: Detach the switch housing electrical connector and remove the housing 89600p09.jpg
    Fig. 7: Remove the door inside handle cup 89600p01.jpg
    Fig. 8: Remove the screws from the door panel in the front and on the upper extension 89600p02.jpg
  8. On Grand Marquis, pry up the screw covers from the door pull handle and remove the screws and handle.
  9. Lift the door panel upward and snap out the panel. Fig. 9: There are also retaining screws located in the map pocket as well as . . . 89600p03.jpg
    Fig. 10: . . . along the bottom edge of the door panel 89600p04.jpg
  10. Disconnect the necessary wire harnesses and remove the panel. To install:
  11. Connect the wire harnesses to the door panel, as necessary.
  12. Install the door panel by pushing in and down until it snaps into place.
  13. Install all self-tapping screws retaining the door trim panel to the door inner panel.
  14. On Grand Marquis, install the door pull handle, tighten the screws and install the screw covers.
  15. Install the push pin covering screw on the panel upper front extension.
  16. Install the inside door handle cup.
  17. Install the window regulator switch housing and install the nut on the outside rearview mirror control switch, if removed.
  18. Connect the negative battery cable. Fig. 11: Lift the door panel upward and snap out the panel to remove it from the door 89600p05.jpg
    Fig. 12: Rotate the door marker lamp bulb and remove it from the door panel 89600p06.jpg
    Fig. 13: Detach the connectors for the trunklid and fuel door release switches 89600p11.jpg
    Fig. 14: Slide the relay connector off of the door panel and remove the door panel from the vehicle 89600p17.jpg
Aug 26, 2010 | Mercury Grand Marquis Cars & Trucks
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
Does the front bottom plate where the speakers are come off?
That speaker grille does come off. There are some adjustments servicers occasionally need to get at behind it, so it usually just snaps on with some plastic fasteners holding it in place. You just need to grab it by the sides and pull forward.
Now having said that, I'll admit I'm not familiar with every Toshiba model. So yours might be different. Every one I've worked on so far has had a snap-on grille. But some manufacturers hide mounting screws under a trim strip between the bottom of the screen and the top of the speaker grille. This strip is held on by snap fasteners, and when you take it off you'll find screws holding the top of the speaker grille in place. So if the grille absolutely doesn't just want to pull off, check for that trim strip method.
Mar 05, 2009 | Toshiba 46H84 46" Rear Projection...
Removing front and back speakers in 1991 Grand Am....
There is a lot involved in replacing these speakers. You should also know that the original factory speakers are 10 ohm speakers. This means that if you replace them with new speakers (most of which are 4 ohm) you run the risk of damaging the stereo, the speakers, or both. This can also cause a potential fire hazard in your car. If you want new speakers, you really should look at installing a new stereo as well.
To get to the back speakers, you will need to remove 2 bolts located under the front edge of the rear seat (bottom). After you remove the bottom, you will need to remove the rear seat (back). This involves removing the bolts that hold down the rear seat belts, which is a large sized torx bit (T-45, T-47, or T-50... Don't remember which). After removing these, lift straight up on the seat back to remove. Now remove the deck brake light housing, and the bracket that holds it. Now the deck cover can be removed. Be careful not to bend it too much getting it out from under the side trim on both sides.
For the front speakers, you must disassemble a good portion of the dash. Remove the screw holding the light switch and the wiper switch housings. This screw is underneath each housing. Once removed, there are dash mounting screws behind them. These screws (and many of the other dash screws) are a smaller torx-bit (T-10 or T-15, don't remember which). Sometimes they use a 7mm bolt. There is a cover panel just above the glove box. This panel is held on with 2 screws located in the glove box. After removing this panel, you will find 2 or 3 bolts holding on the dash. Last but not least, you will find 2 bolts inside each of the defroster vent grilles. These grilles just snap out for easier access to the bolts.
1991 Pontiac Grand Am Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4" Round
Car Audio Front Speakers Location: In Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6" x 9" Oval
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Nov 30, 2008 | 1991 Pontiac Grand Am
Ppc 6670
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. Be certain to order the correct piece.
To replace, you need a micro phillips head screw driver and a T-6 torx screw driver. Also patience, and a steady hand.
You must start at the back of the device, through the battery door. Remove the 2 micro phillips at the top of the battery opening (one is covered with a tamper evidence sticker). Then carefully, starting at the bottom of the camera plate, pry upwards and to the speaker to unsnap the smaller facing. Remove the camera by gentally pulling up to unplug, then unscrew the circuitry and remove. This will expose the 4 torxs (2 in batt opening) to remove the back cover. After screws are removed, gentally work the covers snaps loose around perimeter and remove (pay attention to the speaker wire) unplug it from the circuitboard. Pull the antenna nub to detach.
Remove the screws holding the circuitboard, unpluging the keyboard and slider ribbon cable. Gentally hold the ribbon cable and remove the securing tape. (dont pull too hard!) Pulling the circuitboard exposes the 4 micro phillips screws (2 each side) to detach the slider.
Remove the 4 torx screws on the back of the LCD slider, then gentally pry around to separate the housing.
To remove the LCD / Touch screen you must unplug the ribbon cables. To do this you need to open the connector's trap (black bar). It hinges. Just pry upwards from the ribbon side. Once bar is lifted ribbon will slide out. Be careful if you need to remove the gold foil tape. Remove the single screw holding the ear speaker, and the ribbon should come out. The screen will not come out after gentally prying it free of the holding snaps in the casing.
Installation is simply the reserve. Hope this helps....
Jul 03, 2008 | Audiovox PPC 6700
53 people viewed this question
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
Rommel Balcita
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
