Question about InFocus Corp. InFocus IN2116 DLP Projector, 3000 Lumens
Turns on for about 30 seconds and then turns off
  • 36 Answers
You should check first the fw version. Tha last fw version is v 2.78.30. if the fw is updated it, check the power supply part number, must be P5E84-8101 because the P5E84-8100 have a problem. InFocus IN2116 Projector
Posted on Aug 07, 2014
How would i deactivate the security system on a 1999 chevy caviler
Try to reset security manually. Make sure battery is good. Insert key into ignition turn to on position (make sure to "bump starter"every time you turn to on position). Leave in ignition for 11 minutes. Security light should go off before proceeding to next step. Turn key to off position for 30 seconds. Then turn back to on position for 11 minutes. Then turn to off position for another 30seconds. Then turn to on position for another 11 minutes. Then turn to off position for 30 seconds. Turn key to on position again for 30 seconds. Start engine. That should work if every thing is compatible
Oct 20, 2017 | Cars & Trucks
Model wr-wn300 unable to reset according to instructions.... any help
Usually you can follow the 30:30:30 rule. Turn off and hold the reset 30 seconds, then still holding the reset turn on and wait 30 seconds more, release and the unit will reboot in 30 seconds.
Mar 29, 2015 | Sabrent Computers & Internet
How do I program a transponder key for the ignition in a 2009 Pontiac Vibe?
first the first digit must start with the number 1,or 4 of your 17 digit number for this to work.so fit your chip key in your ignition.
1, insert the key in your ignition turn the key to on for 10 min 30 seconds
2, within 45 seconds turn the key to off then back on for 10 min 30 seconds
3, within 45 seconds turn the key to off ,then back on for 10 min 30 seconds then back on for 10 min 30 seconds.
then after 10 min 30 seconds turn off then on .then start the engine.
Dec 17, 2014 | 2009 Pontiac Vibe
I have a second key for my peugeot 207 57 plate i need to activate the key but not sure if i can activate it myself
On all the cars I have done, you insert the master key and turn the ignition on for 30 seconds, turn it off and insert the other key within 5 seconds and turn it on for another 30 seconds. Turn it off. then try to start the car with the new key. I haven't done a peugeot, though..
Oct 26, 2014 | Peugeot 207 Cars & Trucks
Resetting the passlock
1. First, insert the ignition key and turn the ignition switch to the "On" position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 .
2. Turn the ignition switch off for 30 seconds.
3. Turn the ignition switch to the "On" position (as in step #1) for 11 minutes again.
4. Turn the ignition switch off for another 30 seconds.
5. Turn the ignition switch to the "On" position for 11 minutes a third time.
6. Turn the ignition switch off for 30 seconds one final time.
7. Turn the ignition switch to the "On" position one final time and wait 30 seconds.
8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. If the engine does not start, Go to this link for info
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Sep 08, 2012 | 2000 GMC Yukon Denali
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
Cannot reset to factory settings my linksys WRT120N I tryed with reset button 30 seconds but nothing change
Turn the router off.
Hold the RESET button in, for 30 seconds.
Turn the router on, and see if it has reset.
If not, then with the router still on, hold the RESET button in, for 30 seconds, and see if it has reset.
Sep 30, 2010 | Linksys WRT120N Router
Can a security issue preventing the 1998 deville from starting be fixed?
Yes it can turn your key to ON not crank for 12 minutes then to off for 30 seconds then to on for 12 minuters then off for 30 seconds then to on for 12 minutes and then off for 30 seconds. Be sure NOT TO crank the car at any time during the procedure. after the last off for 30 seconds start up your car and it should be reset.
Apr 09, 2010 | 1997 Cadillac DeVille
InFocus Corp. InFocus IN2116 DLP Projector, 3000 Lumens Logo
203 people viewed this question
Top InFocus Corp. Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Corp. Office Equipment and Supply Expert? Answer questions, earn points and help others
