Question about Fisher Audio Players & Recorders
Stuck CD Magazine
I have an older Fisher Stereo that has a 10 CD Magazine that is stuck in system and getting error message.
  • 24 Answers
You'll have to take the cover off. Look for screws around the back and on the sides. Most likely a cd is wedged in the wrong place. (not fully ejected) and is preventing the magazine from ejecting.
Posted on Jan 02, 2014
szwaan
  • 209 Answers
SOURCE: stuck CDs
If you don't care about the disc player and want to get the cd's out you can easily take it apart yourself[make sure you unplug it]
Posted on Dec 26, 2007
SOURCE: error 99 displayed on cd player. CD player is a Denon DCH-520.
Normally you just hold down the eject button on your stock head unit and it resets the mico computer
Posted on Jan 16, 2008
mjap
  • 107 Answers
SOURCE: Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Posted on Jan 30, 2008
SOURCE: panasonic stereo (model sa-pm19)
I still need help!
Posted on Aug 02, 2008
  • 12 Answers
SOURCE: CD stuck in player.
Take a screw driver with the player on, and push on the side of the cd so that it's being pushed into the player, sometimes this is caused by the cd not going all the way into the player and being stuck in a sort of limbo. I've had alot of issues with mine and took it apart, but figured this out afterwards. might also want to try pushing on the two white plastic things that come over the cd if pushing the cd in doesn't work. Hope that helps.
Posted on May 04, 2009
My alpine CD player is showing a cd 3 error jam
Are all CDs in the magazine? If not, there may be one stuck in the changer
Sep 23, 2012 | Alpine Car Audio & Video
My 2001 Landcruiser will not play dvd/cd. It gets
I have the same exact problem:2001 Landcruiser will not play dvd/cd. It gets stuck. Display of dvd error shows. DVD can not eject. Please let me know if you got it to eject. I tried disconnect/connect the battery for full 5 minutes but did not help.
Apr 20, 2010 | 2001 Toyota Land Cruiser
Code 99
e-99 indicates that there is some type of mechanical jam, the microprocessor requires reset, or the system had some major failure. try to remove power from the system for a few moments, and then reconnect. this will rest the microprocessor and possibly restore function. if there's a disc stuck in the magazine, or stuck somewhere in the loading or unloading sequence, it's sometimes possible to free this but the changer will have to be removed from the vehicle and partially disassembled.
Jan 17, 2010 | Sony CDX-540RF 10-Disc CD Changer
2005 s40 cd(holds 6) player stuck - reads deck error?
that is one of worse nightmare when you have a magazine loader in the systems when the cd get stuck. its common to all cd player some has better luck than others, Only thing I recommend is to take it to your local stereo shop or do it your self taking the unit apart and remove the cd. Keep in mind, when having magazine loader, some of the older unit will not read the new format or burn disk and it will read no disk or error and the cd will get lock. if the unit cant read the cd, majority of the time its does recognize there is a cd in unit. try tuning on and off couple of time and keep pressing eject button. you may have to do it 8-10 times to see if that will release the stuck cd.
Aug 27, 2009 | Car Audio & Video
Clarion arx9270 error
Typically means the CD is stuck, has a reading error, or the magazine is stuck. If jammed, you'll have to clear the stuck CD which may require disassembly. Try removing power and rebooting.
If all else fails, I recommend contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
Jun 18, 2017 | Clarion ARX9270
RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Dec 30, 2007 | RCA RS2531 CD Shelf System
Stuck CDs
Dec 26, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
CDAC ER2
CDAC ER2 usually means a cd is stuck, not reading properly, or that the magazine is stuck or broken. take out all cds and try it with a known good cd (one that played ok in the past). if that doesn't work, try unplugging the unit and plugging it back in.
if it still doesnt work, take the magazine out, power it up so that you get the "no mag" error, then insert the magazine with no discs and see if it still errors out with ER2. if it does, then the magazine is bad, or the changer is bad..
if it works, then try the known good disc again, if it works now, your magazine was probably stuck, or one of the other cd's isn't liked by the changer.
hope this helps,
trin
Nov 17, 2007 | Clarion DC625 6-Disc CD Changer
Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Jul 29, 2007 | Bose Lifestyle 30 System
111 people viewed this question
Top Fisher Audio Players & Recorders Experts
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
