Denon how to connect tv
I have a denon 1802 and never a problem until I bought a new tv without (optical out ). I So can't connect tv straight to avr now. Is there another way around it. TV is h40b samsung on their uk website. We also have a ps3 and sky hd box close by if that helps.
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
MNfisherman
  • 11896 Answers
SOURCE: Need help connecting PS3 to my Denon AVR-3801
You could try sticking a vcr/dvd player in between the connections and using those input/outputs instead.
Posted on Jan 17, 2009
  • 119 Answers
SOURCE: hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Posted on Feb 25, 2009
  • 118 Answers
SOURCE: I am trying to use my Denon AVR-1802 to connect my
connect your analog output from the cablebox to the receiver md/tape in. then connect your tv audio input to the md/tape out of the receiver. or you could just pass it straight from the box to the tv, bypassing the receiver altogether.
Posted on Nov 03, 2009
  • 65 Answers
SOURCE: how do i connect an HD satellite box to my denon
i woud say just one for the video connection
Posted on Jan 17, 2010
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
How do I get audio from my tv to my receiver through an hdmi cable? AVR 2807
Your tv needs to have an HDMI out. If it has just connect that to the Denon. Tv might not have HDMI out so connect an optical cable from the tv's optical out to the Denon's optical in.
Sep 29, 2010 | Denon AVR-2807 Receiver
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
I am trying to use my Denon AVR-1802 to connect my cable box to my TV. The problem is that I don't have any speakers connected to the 1802, I just want to route the cable box's video and audio to the TV...
Nov 03, 2009 | Denon AVR-1802 Receiver
Can not get audio from tv to receiver
You may need to assign the optical audio input to the selected source. Also check to see if the input mode for the selected source on the receiver is set to Auto or Digital.
Sep 29, 2009 | Denon AVR588 Receiver
Hi denon to cable box to samsung lcd
Feb 25, 2009 | Denon AVR-5803 Receiver
Denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | Denon AVR-3801 Receiver
Digital audio cuts out.
I have same DD 5.1 tiny "bursts" problem with satellite HD channel. It is probably problem with Crystal DSP (German site): http://forum.digitalfernsehen.de/forum/showthread.php?t=89328&page=3
"Denon bietet Lösung für EX-Flag-Problem bei den Modellen AVR-1602 und AVR-1802 an
07.08.2002(cr)
Dass die Denon AV-Receiver AVR-1802 und AVR-1602 die mit einem DD 5.1EX-Flag versehenen Tonspur von "Atlantis" und dem "Herrn der Ringe"nicht abspielen können, ist ein spezifisches Problem von einerbestimmten Revision des in diesen Geräten verbauten Crystal DSPs.Dieser Chip wird u.a auch in einigen Kenwood- und Onkyo-Modelleneingesetzt.Da es von diesem Crystal Chip unterschiedliche verbauteRevisionen gibt, von denen aber nur eine bestimmte betroffen ist,werden die beiden Filme auf dem größten Teil der verkauften AV-Receiverohne Schwierigkeiten laufen.
Denon bietet nun für alle betroffenen Kunden, die ihr Gerät beimdeutschen autorisierten Fachhandel erworben haben, eine kostenloseModifikation an. Das Gerät muss beim entsprechenden Fachhändlerabgegeben werden mit dem Hinweis auf das Herr-der-Ringe- bzw.Atlantis-Problem.
Momentan steht nur eine begrenzte Anzahl an DSPs zur Verfügung - Denonhofft, dass kurzfristig ein größeres Kontingent eintrifft.
Denon bittet daher die Kunden freundlich um Verständnis, dass nichtalle betroffenen Geräte auf einmal und sofort umgerüstet werden können."
May 23, 2008 | Denon AVR-1802 Receiver
Denon AVR-1802
might hav eto buy new control modual parts store hi end parts store order one for u
Jan 25, 2008 | Denon AVR-1802 Receiver
Denon remote control unit RC-897
i cannot find a remote online for my denon avr1802 can anyone send me a link or info to my email address, joe.miller1110@gmail.com
Nov 19, 2007 | Denon AVR-1802 Receiver
 Grubhead
Grubhead
