Question about Colormate Shiatsu Recliner
How can i or can i replace a bad switch on my recliner without tearing seat apart
Ford 2008 expedition, power drivers seat won't recline, but everything else works.
Power Recliner
The driver seat has an electro-mechanical backrest adjuster. The backrest adjustment switch is located on the side of the seat cushion side shield and is part of the seat control switch. The recliner motor is mounted to the backrest frame. Power recliners and motors are only serviceable by installing a new backrest frame assembly.
Does yours have Driver and Passenger Power Seats Without Memory Or Power Driver Seat With Memory ?
B1666 Seat Driver Recline Motor Stalled On-Demand If the motor does not operate, Go To Pinpoint Test L . If motor operates, Go To Pinpoint Test M . Take it an have it check !
Does your
May 15, 2016 | Ford Cars & Trucks
Chrysler Pacifica 2006 driver reclining seat won't work just stopped. All other functions work ok
If you look under the seat, you will find several motors. For reclining there could be a few of options to check. Motor being one, and linkage being one, and just wear and tear on the swivel points. Hate to say this, but weight of the person can make a big difference on all I mentioned.
Jul 12, 2013 | Cars & Trucks
Replacing safety switch under seat - how do I get it and replaced?
some of the switches you need to remove the seat cover to install the switch
Jul 08, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My front passenger seat does not recline
power seat mechanical mechinism broken it wont allow seat recline or control switch is bad.
Feb 10, 2012 | 2003 Buick Rendezvous
Driver seat does not recline
can you hear motor running under seat when you press control switch,if not check for power at switch with a test lamp.If power at switch check for power at motor,if it has power, motor probably bad or jammed for some reason.You might need to take out seat to get to recliner motor.
Nov 24, 2010 | 1998 Ford Explorer
The passenger front seat will not recline - how can I fix
2010 Equinox drivers side won't recline.
Found the cable popped off recline mechanism.
Pulled back the lower seat panel near the recline lever after removing one torque screw located on said panel which is on the back of seat. Works great now. By the way, Freedom Chevrolet in San Antonio, Tx, without diagnosis, wanted to charge my girl friend $860 to replace the whole assembly.
Feb 10, 2010 | 2005 Chevrolet Equinox
CAN YOU MANUALLY RECLINE A POWER SEAT THAT IS STUCK
only 4 bolts hold the seat in they may have a plastic cover on them that can be popped off with a screwdriver.remove the bolts and lean the seat back check the wires going to the motor and make sure it has power going to it.Don't know of any way to manually recline the seat without taking it apart.
Jun 07, 2009 | 2002 Nissan Maxima
Camry power driver seat motor won't return from recline position
it has three septet motors with gears
if one is bad you will replace it
Feb 13, 2009 | 2003 Toyota Camry
97 Ford Explorer - Driver Seat Repair- 2 Dr V6 SOHC
you can replace the recline lever assy without removing the seat
Jan 16, 2009 | 1999 Ford Explorer
Passenger seat back will not move either direction
Motor on the seat may have gone out, contacts in switch got dirty or worn, or assembly reached limit and stuck. Try sitting in it pushing back hard and adjust. If not youll need to replace switch,b take seat apart to fix or replace.
Dec 06, 2008 | 1989 Mercedes-Benz 300-Class
Colormate Shiatsu Recliner Logo
Top Colormate Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Colormate Furniture Expert? Answer questions, earn points and help others
