Question about Intuit Quicken Starter Edition 2009 Full Version for PC
Gan't get in to it
When I click on the QW.EXE a window comes up with.
One of the library files needed to run C:\QUICKENW\QW.EXE cannot load in the 16-bit Windows subsystem because it is a Win32 DLL.
I have81003004 problem ,I use LAN connection not dial up .When I make setting up for proxy Dial up can`t be changed Thanks alot
Posted on May 21, 2009
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
Tip
How to Register DLL files
On Microsoft Window's operating systems, a DLL stands for Dynamic Link Library. DLL's are relatively small files that include a library of functions- usually data that can be shared across multiple applications. DLL's are called upon by various applications and can be loaded and utilized by these applications concurrently.
Registering a DLL
There are two easy ways that a DLL can be registered in your Window's operating system's registry, the first is the simplest, known as self registering files, the second way is to manually register a DLL.
Self Registering Files
It should be noted that many DLL files are self registering, they include information required to store themselves in the operating system's registry. As the name states, self registering files require no human intervention. Self registering files will automatically store themselves on your machine and become accessible when needed. Besides DLL files, other types of files that are sometimes self registering include .EXE and .OCX.
Manually Register Files
The second method used to register DLL files on your computer is via manual registration. Manually registering a DLL file is quite simple and can be done in only a few steps.
1. The first step is turn on your computer, launching your Window's operating system.
2. Once your Window's operating system has loaded completely, click on Start and then click on Run.
4. Once the command is input into the Run field correctly, press Enter.
5. Once the DLL has been registered, you should receive a confirmation in the form of a pop up box. This message will list your newly registered DLL file and confirm that is was successfully registered into the registry.
on Aug 28, 2010 | Computers & Internet
Tip
Set a new Windows Explorer launch folder When you run Windows Explorer, it...
Set a new Windows Explorer launch folder When you run Windows Explorer, it always opens to the Libraries folder. That's fine if you use Microsoft's default file organization, which designates Libraries as the overall container for your folders. But what if you don't? You might prefer to have Windows Explorer open to Computer or any other folder you choose. Here's how to do it:
1. Right-click the Windows Explorer icon on the taskbar (it's the one that looks like a folder), and then right-click the Windows Explorer icon from the context menu that appears and select Properties. The Windows Explorer Properties dialog box appears.
2. You'll have to edit the Target field on the Shortcut tab of this dialog box in order to change the default location at which Explorer opens.
If you want Explorer to open to a specific folder, simply enter the name of the folder, substituting your folder name for Folder, below, like this:
%windir%\explorer.exe c:\Folder
So to open Explorer to the folder named Budget, you would type this in the Target field:
%windir%\explorer.exe c:\Budget
If you want Explorer to open to special, pre-set locations, such as Computer, you'll need to enter special syntax in the Target field. Following is a list of three common locations and the syntax to use, followed by the syntax for the Libraries folder in case you ever want to revert to the default.
  • Computer: %windir%\explorer.exe ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}
  • My Documents:%windir%\explorer.exe ::{450D8FBA-AD25-11D0-98A8-0800361B1103}
  • Network: %windir%\explorer.exe ::{208D2C60-3AEA-1069-A2D7-08002B30309D}
  • Libraries: %SystemRoot%\explorer.exe
3. After you've changed the Target field, click OK. Next time you launch Windows Explorer, it will open to the new location you've designated.
on Jan 12, 2010 | Computers & Internet
Problem with Rise & Fall: Civilizations At War for Windows 7. how to open ebooklibrary.exe
To install and run "R&F Civilizations at War" in Windows 7:
1) Run the Setup file and install the game
2) Google and download "http://www.ausgamers.com/files/process/24085/rise-and-fall-civilizations-at-war-patch-v115-beta" and "http://www.star-force.com/support/sfdrvup.zip".
3) Install "Rise and Fall: Civilizations at War Patch v1.15 beta".
4) Run the game, let it install required libraries and then reboot.
5)Run sfdrvup.exe and update the protection driver. Reboot.
Now the game should run in Windows 7.
Jan 08, 2012 | Computers & Internet
Only my desktop picture is there when turned on nothing else
Hi.
Based on the information you have provided, it seems that the issue might be due to the "Explorer.exe" System file.
This is the file which loads the Windows Explorer.
The Windows Explorer in-turn loads all the required Startup Applications.
As the Applications are loaded and the icons are not displayed, you may run the "Explorer.exe" file manually.
By doing this, all the Startup Applications should be loaded.
Steps to run the "Explorer.exe" manually:
1) Press the "Alt, Ctrl and Delete" keys simultaneously. 2) Then, check if you are able to view the "Task Manager". 3) Click on the "File" tab and select the "New Task" option. 4) In the Run command window, type "explorer.exe" and press Enter. 5) This command should execute the "Explorer.exe" System File. 6) By executing this System file, all the Desktop icons should be restored.
Hope this helps.
Please feel free to contact for further information and assistance.
Jan 01, 2011 | MSI Wind U100-016US Laptop
Quicken 2009 won't load any more. using windows vista.
Ok, this basically means the ini file is corrupted normally. What you'll have to do is either reinstall quicken 2009 or try a repair on it. You can also manually go to c:\Program Files\Quicken\qw.exe and see if the shortcut is bad that you have been using. If you don't have the disk, go to start, settings control panel, add remove programs or programs and features. Locate the program. Right click on it, click change. Then check the feature that gives you the option to repair the software. BACKUP quicken files if they aren't on a disk.
Jun 11, 2009 | Intuit Quicken 2008 Deluxe Full Version...
Quicken 1996 Edition - My computer lost it I don't know how my 1996 edition of Quicken so I down loaded the 6 - 3 1/2" disks but when I click on QW.EXE it comes up with (One of the library files neede
Hi Bruce,
Time for a new Quicken, my friend. and maybe a newer computer. I remember something about Quicking having trouble migrating to 32 bit computers.
Find a newer quicken on e-bay or at your computer store that also handles used software. Quicken sells the new version now at their site for $78.00
Make sure you have a good back up before youj start.
I hope this helps
a
May 21, 2009 | Intuit Quicken Deluxe 99 for Windows...
One of my library files needed to run control panel is missing
If the system came with a cd for the keyboard, reinstall it. otherwise, reinstall the windows.
Apr 29, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Windows cannot find 'gphone.exe'
Gphone.exe is worm which spreads via instant messengers. It usually affects Yahoo! Messenger and Google Talk applications. Gphone.exe send a message and invites victims to visit a website. If clicked upon, the link actually delivers a copy of Gphone.exe infection.
Most likely you have a security program that detected and removed the threat but windows is still trying to load the file on startup, thankfully it isnt able to because the threat is gone so windows is displaying that error message to let you know it was not able to load the file.
Go to Start > Run> type "msconfig" and press enter. click the startup tab and uncheck the box that says "gphone.exe". (it may have a long file or folder path in front like c:windowssystem32).
Go to this website if you need further removal instructions:
http://www.spywarevoid.com/remove-gphoneexe-gphoneexe-worm-removal.html
Jan 21, 2009 | Computers & Internet
Age of Sail Privaterr's Bounty will not play
You need to run it under windows 98 compatibility mode:
To do this locate the file "privateer.exe". By default, this file is located in Program Files/Global Star/Privateers Bounty - Age of Sail 2.
- Right click on the privateer.exe and select Properties.
- Click the Compatibility tab.
- Check the Compatibility Mode box by clicking in it.
- Use the drop down menu to select Windows 98/ME.
- Click Apply, and then click OK to close the window.
Hope this helps.
Graham.
Jan 08, 2009 | Global Star Software Age Of Sail 2:...
Intuit Quicken Starter Edition 2009 Full Version for PC  Logo
87 people viewed this question
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
