Question about Honeywell Programmable Thermostat Heater
Control box beside boiler in garage is flashing
Since tenants left, i have been unable to use/programme the hand held programmer. I have changed the batteries.The hand set is showing all clear numbers. can set time etc and use programme buttons but heat will not come on .had boiler checked out as under guarantee but they said problem with box beside boiler. I have to turn boiler off using switch and then press the small button on the b ox and the heat will then come on but a red light keeps flashing.
  • 109 Answers
SOURCE: Our TH8000 Series Programmable Thermostat
try holding the filter button in for three seconds, if that doesn't reset the timer try the filter button and the temp. up button at the same time for three seconds.
Posted on Mar 31, 2008
  • 15 Answers
SOURCE: We have a newly installed
You have wired the cooling (yellow) and the heating (white) backwards.
Posted on Sep 19, 2008
SOURCE: flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Posted on Feb 18, 2009
SOURCE: my boiler keeps firing up
I had the same problem. I traced it to the micro switch in the water/central heating motorised valve having shorted out.
I replaced the (Honeywell) motorised valve and it is now only running when it should.
Jo
Posted on Apr 23, 2009
james3751
  • 614 Answers
SOURCE: ac will not kick on
That is just a change filer signal. It does not chut your ac down to clear some tstats you push up and down keys at same time. I need to know what kind of tsta you have and I can tell you how to clear it. Russ
Posted on Jul 23, 2009
How do I slow down my power chair
You may have a faulty speed control depending on the model. There are hand held programmers that are used to adjust the speed and other parameters. Your local dealer or mobile technician should be able to make that adjustment for you.
Jun 20, 2014 | Select Jazzy Used Electric Wheelchair
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
Heating wont come on. honeywell system the request box in kitchen requesting for it to come on but thermostat not coming on and boiler in garage not kicking into action hve tried resetting both thermo
Check transformer near on on boiler circuit board. the transformer provides a low voltage power source to operate some thermostats and relays at the furnance control board. May need new transformer also check wiring to thermostat
Sep 25, 2017 | Honeywell Programmable Thermostat Heater
Bat lo flashing periodically
You need to change batteries. The bat lo light flashes when you have about 10% battery life left. Rus
Dec 05, 2009 | Honeywell CT3200 5-2 Day Electronic...
Alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Jan 05, 2009 | Water Heaters
Changing boiler programmer
take digital pictures - label all wires and reconnect - you do not need manual.
Oct 27, 2008 | Water Heaters
Heating & Cooling Logo
139 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
