Question about Panasonic Cameras
Model No. RQ-356 drive belt loose
How do I replace the drive belt? Where can I get a belt? Thanks
  • Harrie Jan 02, 2014
    Hi George Strella, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? In what digital camera can we find a drive belt?
4 Suggested Answers
SOURCE: 356 BELT ERROR
Please Google your problem.
The method in the following link helped us to solve our same problem.
<OKI C9300 Code 356:Belt Unit Life>
http://www.fixyourownprinter.com/forums/printer/53306
There is a shortcoming, however, in this method:
The reset process resets the usage stats of toners, drums, fuse and belt. After reset it displays on Print Supervision as if all the a.m. parts have been replaced with new ones.
Posted on Mar 04, 2009
  • 217 Answers
SOURCE: code 356 Belt replacement needed for Oki C5150
By removing all the cartridges you'll find the belt. Replacing is very simple. Lift it out and put in the new one.
Posted on Jul 30, 2010
whitejeff74
  • 41 Answers
SOURCE: I have a craftsman riding
there is no adjustment on the drive belts but you do have a clutch adjustment to do this you have to remove the mowing deck (NOTE) draw a digram of the way the deck belt runs adjust the clutch lever from the bottom of the mower, test mower with out the deck on and if this solves the problem reinstall the deck....
Posted on Jul 26, 2011
Am getting error 356: Belt Life - Is there a way to replace that yourself?
I suspect this is the transfer belt that needs to be replaced. I've seen the error as 355 not 356 but that could be depend on when in the life-cycle of the belt you see the error. You can replace this yourself. The entire list of steps is given here for the C5150n: http://my.okidata.com/man-c5150-c5200.nsf/MOCContents/380C6DEE82CF117285256CC50063D2D3?OpenDocument . (The entire manual is here: http://my.okidata.com/man-c5150-c5200.nsf/InsideUsersManual?OpenFrameSet .)
The transfer belt, part 42158711, costs ~$210 from this vendor: http://www.fastprinters.com/ProductDetails.asp?product_id=OKI-42158711 . It's probably close to $250 from OKI. Staples has it for $270; Amazon.com lists one for $166.
To replace the transfer belt, you have to take out the image drums and put them in black plastic bags (if you take more than 5 minutes to replace the belt). Remember their order. Then locate the blue locks on each side of the belt unit and rotate them about 45 degrees to unlock them. Lift out the belt unit using the handle at the front. Unpack the new belt and hold it with the handle to the front of the printer. Catch the gear at the back with the drive gear on the belt unit. Lock the blue locks and then reinstall the image drums.
I hope this helps.
(If the problem is the motor belt, that's a different issue.)
Feb 04, 2013 | OKI C5150n Led Printer
I have a craftsman riding mower model # 971.274822 and recently replaced the mower drive belt. Although it is the correct belt, 42", it is really loose! How do adjust the tension? Thanks
Jul 26, 2011 | Garden
Belt installation is too loose on Maytag dryer model # pye2300ayw? Trying to fix it need a diagram??
Hi and welcome to FixYa, I am Kelly.
If the belt is loose it is most likely stretched / worn and should be replaced:
The idler (item5) of this drawing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=630165#d630165
See routing here: http://www.repair-help.com/kb/index.php?article=105
The drive belt is item 5 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=695560#d695560
The top must be opened and the front panel removed to install the belt.
Here is a link to step by step "how to" instructions.
http://www.ehow.co.uk/how_7277908_do-belt-maytag-pye2300ayw-dryer_.html
Make sure to inspect the rear drum rollers while you have the dryer open. Item 7 this link:
Flat drum rollers or hard to turn rollers will cause the new belt to fail prematurely.
Additionally if the front or rear drum seals are worn it can cause the belt to be loose. These are glued on with high temp adhesive.
The front seal is item 10 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505910#d28505910
The rear seal is item 2 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505913#d28505913
High temp adhesive: http://www.appliancepartspros.com/part_details.aspx?part_id=4284239
By replacing the items above your dryer will operate like new again and extend the life of your dryer by many years.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Maytag Dryers
I have a craftsman model 971.271552 riding mower. I was driving it and it made a noise. Now it will not move. I can push it in neutral, but not when in gear. The belt seems to be o.k. It starts and runs...
The transmission has given up the ghost. Pull the release pin - get it on jack stands and pull the batter. Remove the battery box and look for a tube sticking straight up from the transmission. Stick a straighened hanger down the tube and do a 'stick check' on the fluid level. Fill as needed.
Nov 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Code 356 Belt replacement needed for Oki C5150
Jul 24, 2010 | OKI C5100 Laser Printer
Cassette player plays tapes for awhile then will go garble like and auto reverse back and forth once then shut off. I noticed it seems the tape is getting kinked up or stuck on the rollers. looked for...
The reel drive of your set is not taking up the tape and resulting in no detection of reel pulse. this makes it switch over and the result happens again. Please clean up your drives, the rollers, change the belt and check the reel drive arrangement, the motors. I am sure the mechanism must be reset with new belts . This must solve your issue. Good day
Jun 20, 2010 | Panasonic RQ-SW33VA Personal Cassette...
Error code 10-356
Hi
10-356 code i pws mode
remplace the fuser
Feb 09, 2010 | Xerox DocuColor 12 Printer
How do you replace the drive belt on Whirlpool dryer?
What is the model number of the dryer.
Nov 14, 2008 | Dryers
356 BELT ERROR
Aug 16, 2008 | OKI C5200n Laser Printer
Cameras Logo
19 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
