Question about Bosch Dishwashers
Bosch dishwasher door latch stuck
Dishwasher (SHE3AR75UC/07) door latch is stuck in locked position. How do I open?
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
jonniewalker
  • 1029 Answers
SOURCE: Asko door latch stuck
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Posted on Sep 20, 2008
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
here2helpBSH
  • 27 Answers
SOURCE: Bosch Dishwasher SHX46A latch stuck in down possition.
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
Posted on Mar 19, 2009
My dishwasher runs but door is in locked position. it will now run with door open and the door wont close/lock
It sounds like your door latch got tripped into the closed position (even though your door is open). You MIGHT be able to use a screwdriver or some tool to be able to pull the latch lever back out to the open position, but it might also be necessary to take the door apart to get to the latch to be able to reset it. The real problem is that if it happened before, it will probably happen again. So the real solution is to replace the latch assembly.
May 31, 2015 | Jenn-Air 24 in. JDB2100AW Dishwasher
Rear latch lock stuck in the open position
use a round bar ( a screw driver ) and place it under the latch and pull the latch out as you press the button to unlock as if you were opening the door.
Jan 06, 2014 | 2008 Chevrolet Uplander
How do I unlock my dishwasher door?
To avoid damaging the mechanism, you must remove the cover of the dishwasher and with a screwdriver blade can unlock the door from inside.
Jul 04, 2013 | Cars & Trucks
Kitchenaid dishwasher KUDS30IXBL door locked open, will not close
There should be a type of hook inside the hole where the door latches to the machine. Hold the handle up and rotate the hook latch so the open side is pointing towards the machine. The click you heard was the latch that holds the door closed moving to the closed position when the door was open, and it needs to be in the release position.
Jan 28, 2013 | KitchenAid KUDS30IXBL Builtin Dishwasher
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
Door Open but latch in closed position - HELP!
You need to operate the door release handle at the same time as applying pressure to the latch you can see just inside the door (imagine which way it would move if the thing was working as designed), the tech has possibly simulated a door closed position for testing purposes.
Apr 22, 2010 | Neff 24 in. S5456 Built-in Dishwasher
Door latch on both front doors are stuck in locking position while the doors are open. This is causing me not to shut the doors. how or what can I do to fix that?
try spraying with wd40 and hold the inside handle and use a screwdriver or your finger to move the latch catches,im assuming that the latches are in a closed position.You may have to unlock the latch with a key first
Feb 07, 2010 | 2001 Ford Windstar
Our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Nov 07, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
49 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
