Question about Taylor 1478-21 Gourmet Digital Cooking Thermometer/Timer
Probe temperature always reads LO - Taylor 1478-21 Gourmet Digital Cooking Thermometer/Timer
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
I installed a model thm101b on my shop heater, which i do not leave on when i'm not using the shop. after leaving the place without heat overnight'the thermostat showed a lo reading. after putting new...
The Lo reading on the thermostat comes on when the temperature is below the range of the thermostat .the lowest readable temperature is 40f I believe. So anything below that the thermostat just reads Lo. This is normal for this brand of thermostat.
hope this helps.
Bob
Sep 01, 2017 | Intertherm Heating & Cooling
I have a frigidare range and it is flashing F10 and Beeping repeatedly
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Here is the probe to order.
Here is the EOC to order.
Jan 07, 2013 | Frigidaire PLEF398AC Electric Kitchen...
My house was hit by lightening last night. Since then my Frigidaire stove, blinks F3 when turned on.
Hi.
F3 means that the temperature sensor is open. Locate and remove the temperature probe. Use a multimeter to read the impedance at probe contacts. At room the probe will read about 1.1KOhms. If it reads infinity (open), then the probe must be replaced.
If the probe is good, test the wiring between probe and electronic control. If wiring and probe are good, then the problem is electronic control.
Test the probe first.
Apr 25, 2011 | Frigidaire Kitchen Ranges
I have a Braun ThermoScan Type6013 have changed batteries twice but keeps coming up LO when try to read a temperature, any ideas?
Problem:
Temperature taken is not within typical human temperature range (93.2 °F - 108 °F / 34 °C - 42.2 °C).
Solution:
Make sure new, clean lens filter is properly inserted. Then, take a new temperature.
Feb 21, 2011 | Braun Health & Beauty
"PROB" shows when fryer is
Computerboard will display "PROB" error when it could not sense resistance reading from the temperature probe sensor (temperature probe sensor is either open circuit or short circuited). Check first the temperature probe connectors, tighten loosely fitted connectors on wiring harness and computer board, then check if the wires are not damaged. Disconnect the temperature probe and check the resistance using an ohm meter. If the reading is either zero or infinite, you have to replace the temp probe.
Dec 18, 2010 | Pitco Frialator SG14 Deep Fryer
Hobart L30 show code P3 and tempreture rises high Very quickly before it finsh filling
P3 refers to one of the dishwasher's three temperature sensors: sump temperature, booster heater temperature, or rinse water temperature. The dishwashers control circuitry has determined one of them is open or shorted, or at least out of range.
Judging from the symptom you mentioned, that you see rapid temperature reading changes before it finishes filling, I'd say it's probably the sump probe (because that's the temperature displayed during the fill cycle), located under the large removeable screen inside the dishwasher.
To test or replace, remove the small access panel at the lower front of the dishwasher (2 screws).
After the dishwasher has reached a good normal operating temperature, unplug the sump probe connector (white plastic connector with two small black wires going to it and coming from the area mentioned above where the temp. probe is. Using a multimeter, test the resistance of the probe. If the water in the dishwasher is hot (150 deg. F or more), you should read somewhere in the area of 5,000 to 10,000 ohms. If your measurement varies significantly from this range, replace the probe- most likely you'll see a reading near zero ohms or a very high reading, possibly an open-circuit probe (infinite resistance i.e. "OL" indicated on most multimeters).
It's possible I'm wrong about which temp. probe P3 refers to. There is also a temp. probe on the booster heater and one on the rinse piping on the rear of the dishwasher. Test procedure is the same for all of them, although the probe on the rinse piping is not constantly subjected to hot water so testing at room temperature would result in higher resistance value (lower temperature means higher resistance for these temperature probes).
Nov 18, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
Error code F 10 during broiling. model #790.78649601
The first thing to check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
Aug 01, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Taylor 1478-21 Gourmet Digital Cooking Thermometer/Timer Logo
514 people viewed this question
Top Taylor Home Experts
john h
Tom Chichester
Are you a Taylor Home Expert? Answer questions, earn points and help others
