Question about Watches
2115-sr626sw how do I know which # is the serial #?
Change the links on a sr626sw
An SR626SW is a battery reference nothing to do with the make or model of your watch.
Feb 21, 2017 | The Watches
How do I set the month on a accutime watch sr626sw
sr626sw is the battery type, not the model.
Nov 27, 2016 | The Watches
Size battery
If it's just the battery it will usually take a AG1/364 battery or SR626SW. The batteries are cheap if you buy it on ebay.
Oct 26, 2013 | Fossil ES9825 Wrist Watch
BEVERLYHILLS POLO CLUB WATCH MEN
Put a screw driver in the hole on the clasp. It shouls flip up and then you can slide the clasp up and down the watch band.
Dec 26, 2012 | Watches
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 | Watches
I don't know how to set my watch . It is a japan movement watch #sr626sw
626sw is the battery # you can send a picture of the watch I may be able to help you since I worked with watches for 19 years.
Nov 18, 2009 | Watches
Beverly HIlls Polo watch needs band adjustment
All you prepare a piece of jewelry screw.There will be very tiny screw in the side of the band you better screw it carefully and when the screw is out detach it,and size it that's you like size comes out.That all if want to resize desame what did in the other side. Always do it slowly so there no scratch or visual impaired damaged.
Jun 16, 2008 | Beverly Hills Polo Club 22-710TTS
Watches Logo
10 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
