Question about HP Pavilion tx1000z Notebook
Hard disk not gettting detected
How to change hard disk in my laptop HP pavilion tx1000
  • naseerapm May 21, 2009
    thank u Ekse, i have one more doubt, how can i find out whether my hard disk is having the problem or the cable connecting to the laptop? is there any way out?
    will it be solved if the hard disk is repalced?
    Thanks again, but unfortunately its not covered by warranty.
  • HP Master
  • 13,433 Answers
In most laptops the hard drive is in the bottom of the computer, under a cover that is hold closed atleast with 2 screws. after removing those screws you should be able to open the hard drive cover, inside you will find the hard drive on a holder, you will in most laptops have few screws that hold the holder still, unscrew the holder and carefully pull the hard drive to the other direction DONT PULL UP, in most laptops you have to pull the drive horizontally or you might damage the connectors.
ones you have the drive and the holder out, you will need to unscrew the hard drive from its carriage / holder.
Screw in the new hard drive and place it back to the laptop the same way you took the old one out.
Posted on May 21, 2009
  • Ekse May 21, 2009
    the problem could be with the motherboard of the laptop, it might be best to take it in for testing, also is it covered by warranty? if its on warranty hp will deal with it.
    might be cheaper to take the laptop to someone who can test it with another hard drive instead of buying another one. I can't guarantee that it will fix the problem, since we don't know what the real problem is.
Hp say hard disk failed 301
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 25, 2013 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hp tx1000 turns on and off
Remove the main battery, any change? next sub the power supply for another, no improvement! remove the hard drive, and sub out the ram memory one at a time. If the problem continues it is a motherboard issue, at this stage it must be evaluated.
Jun 28, 2012 | HP Pavilion tx1000z Notebook
I have an HP Pavilion dv6500, and while I was working on my laptop it suddenly shut down by itself and restarted. When it rebooted, a message came up saying "Operating System not found". I...
Your hard drive may have failed.
I suggest you remove your hard drive and re-connect it to your laptop to make sure it is make proper connection. Boot up and go into the BIOS to see if the hard disk is detected.
If the hard disk is not detected then most likely the hard disk has failed.
To get your laptop working, you will need to purchase a new hard disk and install Windows on the new hard disk plus the Pavilion device drivers and your programs,
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Dec 18, 2010 | HP Pavilion dv6000z Notebook
My laptop hp pavillion tx1000 satarts the light`s work but no have image on the screen the cpu fan and the hard disk works
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Oct 15, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion zv6100 laptop CMOS will not recognize the HD
You could have a faulty disk controller. Try inserting a different working hard disk into the HP and see if it can detect it in the BIOS. If not then the disk controller is faulty and this is a motherboard problem. A replacement motherboard may not be worth it, put your money towards a new laptop and put the hard disk into an USB hard drive adapter case and use it as an USB external hard drive.
Jul 15, 2009 | HP Computers & Internet
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
HP Pavilion tx1000 bad video card and wireless
This problem from the on bord video chips. we can fix that problem 100%. AND charg the good price just the 40% of the good motherboard price.
http://cgi.ebay.com/HP-LAPTOP-MOTHERBOARD-FLAT-REPAIR-TX1000-AMD-441097-001_W0QQitemZ110442914060QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item19b6e9210c
Mar 12, 2009 | Computers & Internet
XP on HP Pavilion dv2000
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
For the laptop with no hard drive detected, this is most likely because Windows XP does not recognize SATA drives by default, which the laptop most likely has. To solve this, you will need to enter the BIOS setup utility (most likely Delete or F1 on startup). From there, you will need to change the drive mode to Compatibility mode. I'm not sure where this would be, but if you check in your laptop manual, you can probably find this somewhere.
For the 2519TU, download and install this for the LAN driver: ftp://ftp.hp.com/pub/softpaq/sp30001-30500/sp30264.exe it should work just fine.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
151 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
